> Installing the Lilliput 619GL 7" Touchscreen Monitor
post Apr 2, 2008 - 4:07 PM
tomazws
Joined Oct 30, '04
From So Cal
This post is about fitting the 619GL onto the double din slot
So here's the Lilliput 619 touch screen:
The whole LCD assembly can be forced into between the 2 clips on the panel, but the top hits the air-vent (about 5mm too long).
And the bottom is also too long (about 10mm over):
So, instead of fitting this as is like pittfirefighter did with his 629, we'll have to do some cutting tongue.gif First we'll have to break the warranty and take this thing apart:
From my measurements, I'd have to cut the case by following the existing gutter on the front casing. Not only it'd be a perfect fit, I also get to retain all the screw holes on the front casing:
I went to Home Depot a bought a $5 hacksaw. Oh, wear a mask or something because it smells when cutting the plastic. After the cut and a little filing, I got the front case to look like this:
See, perfect fit biggrin.gif ! Instead of taping it or whatever, I decided to super glue it onto the panel:
Since all the screw holes are still there, I can just mount the monitor the way it came from the factory:
And the back casing, I also need to cut the top and the bottom, and some of the sides to make clearance for the center panel clips:
Connected all of the wirings and mounted the back panel. As for the buttons on the bottom, I just taped it on the back of the casing later on:
You like it?
This post has been edited by tomazws: Apr 12, 2010 - 3:13 AM
post Apr 2, 2008 - 4:16 PM
D-Man
Joined Jan 18, '08
From Houston
what about the screens buttons?
Damn D-Man - most impressive.
post Apr 2, 2008 - 6:08 PM
tomazws
Joined Oct 30, '04
From So Cal
QUOTE(D-Man @ Apr 2, 2008 - 2:16 PM) [snapback]660935[/snapback]
After programming the Lilliput to auto-power up, then you don't even need your buttons at all.... I just taped my buttons to the back side of the casing.
For auto power up the Lilliput, you can read this post here:
http://www.mp3car.com/vbulletin/lcd-displa...ming-guide.html
post Apr 2, 2008 - 6:22 PM
i did not know they existed.. Found this..
http://cgi.ebay.com/LILLIPUT-CAR-PC-Motori...1QQcmdZViewItem
post Apr 2, 2008 - 8:29 PM
D-Man
Joined Jan 18, '08
From Houston
okay, cool then.
post Apr 2, 2008 - 9:25 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
Wow thomas looks great! What are you using to operate everything?
post Apr 4, 2008 - 11:06 AM
tomazws
Joined Oct 30, '04
From So Cal
QUOTE(MaskedMan @ Apr 2, 2008 - 7:25 PM) [snapback]661064[/snapback]
The touch screen smile.gif The screen is auto on/off and the laptop is auto wake up/hibernate.
Here are some night Pics:
This post has been edited by tomazws: Apr 4, 2008 - 11:08 AM
post Apr 4, 2008 - 10:02 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
Have you had any problems with your screen at all? I've been through 3 screens in my Celica and each one had a different problem. The first one I had didn't do too well in the daytime when my car was hot on the inside. The second one didn't show picture well during the daytime, so on a bright day, I could barely see anything on the screen. The one I have now works great, but when I have the top down, the sunlight will reflect off the screen and blind me frown.gif .
This post has been edited by MaskedMan: Apr 4, 2008 - 10:03 PM
post Apr 6, 2008 - 7:45 PM
Jaws4God
Joined Mar 27, '04
wow, great job!! i'd never try that with a touch screen... Any pics during the day in the car? smile.gif
post Apr 7, 2008 - 11:45 AM
tomazws
Joined Oct 30, '04
From So Cal
During the day is OK. Minor reflections. I'll have pictures.
post Apr 7, 2008 - 12:07 PM
vincent_doggy
Joined May 25, '06
From Hong Kong
QUOTE(tomazws @ Apr 8, 2008 - 12:45 AM) [snapback]662222[/snapback]
Buddy... masterpiece, need one of those, when is your ETA to HK?
post Apr 7, 2008 - 1:01 PM
tomazws
Joined Oct 30, '04
From So Cal
QUOTE(vincent_doggy @ Apr 7, 2008 - 10:07 AM) [snapback]662225[/snapback]
Buddy, Lilliput is "Dai Look Fall". I found this info for you:
Headquarters/Head Office
Hong Kong Golden Sun Electronics Development Co
Unit D, 11/F, Block B
Marvel Industrial Building 17-23
Kwai Fung Crescent, Kwai Chung
NT
Hong Kong SAR
Tel: (852 ) 24333985
Fax: (852 ) 24344805
Key Contact:
Mr Wang, Nanjin
or
Zhangzhou Lilliput Electronics Co. Ltd
Optoelectronic Mansion
Hengsan Road
Lantian Industrial Zone
Zhangzhou
Fujian
China 363005
Tel: (86 596) 2109323 (86 596) 2109815
Fax: (86 596) 2109815
post Apr 7, 2008 - 9:55 PM
vincent_doggy
Joined May 25, '06
From Hong Kong
QUOTE(tomazws @ Apr 8, 2008 - 2:01 AM) [snapback]662242[/snapback]
NT
Hong Kong SAR
Key Contact:
Mr Wang, Nanjin
or
Hengsan Road
Zhangzhou
Fujian
China 363005
Thanks for your info., but I really need your craftsmanship...for installation
post Apr 10, 2008 - 6:46 PM
tomazws
Joined Oct 30, '04
From So Cal
I still haven't taken any pictures yet as my car's in the shop right now.
post Apr 10, 2008 - 7:06 PM
palooke
Joined Sep 13, '05
From Kansas
I fabricated a XENARC screen to my center dash. The great thing is the XENARC is built with auto-power on functions. I will upload a picture when the car gets back from the body shop.
post Apr 10, 2008 - 7:44 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
Why is everybodys' car in the shop frown.gif. I wanna see pictures smile.gif.
post Apr 10, 2008 - 9:47 PM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
exactly what all is needed for one of these... and has anyone made a carputer off a linux system?
and what programs are you using on the laptop to control everything?
post Apr 11, 2008 - 2:55 AM
tomazws
Joined Oct 30, '04
From So Cal
QUOTE(MaskedMan @ Apr 10, 2008 - 5:44 PM) [snapback]663410[/snapback]
Lady in the van made illegal lane change straight into my passenger side...
post Apr 11, 2008 - 8:05 AM
D-Man
Joined Jan 18, '08
From Houston
QUOTE(tomazws @ Apr 11, 2008 - 2:55 AM) [snapback]663506[/snapback]
post Apr 11, 2008 - 4:40 PM
palooke
Joined Sep 13, '05
From Kansas
QUOTE(MaskedMan @ Apr 10, 2008 - 7:44 PM) [snapback]663410[/snapback]
Summers coming my friend. I had a great deal of work done.
The center dash piece I frabricated to look factory. I will upload some pics of it and im willing to take it apart to show how its is done. It really quite simple. but takes some effort sanding and such.
I like what tomazws has done. I just wanted a factory look. to do so you need to buy an extra monitor bezel from the factory. In my case Xenarc. it was only $27 and then some Dynatron, sandpaper, primer, paint and lots of elbox grease. with a bit of effort I have a center dash with a radio head unit a touchscreen AND my clock. I had to redirect air flow...but its a vert...i really dont care.
Lo-Fi Version Time is now: April 22nd, 2025 - 10:17 PM
