> 935 cast manifold
post Apr 2, 2008 - 5:43 PM
celicaGT96
Joined Aug 14, '05
From Corpus Christi Tx
will it fit on the 3rd gen 3sgte?? i know the bolt numbers are different but it looks like it will line up.
can someone please confirm, thanks
post Apr 4, 2008 - 10:54 PM
celicaGT96
Joined Aug 14, '05
anyone??
post Apr 5, 2008 - 8:07 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Absolutely not. A ct26 to T3 adapter would be a better choice:
https://935motorsports.com/catalog/product_...products_id=917
post Apr 5, 2008 - 12:53 PM
celicaGT96
Joined Aug 14, '05
but ill be using a t3 turbo..side by side i have all the bolt holes that the seven has just not the two bottom corner ones.
post Apr 6, 2008 - 6:25 AM
pitcelica
Joined Jan 28, '07
From Québec, Canada
This cast manifold is badly designed. Because the wastegate is located on only 2 of 4 runners, you will have boost creep for sure. The best way to do it is to buy a CT26 to T3 adaptor with a 38mm wastegate flange
Lo-Fi Version Time is now: November 30th, 2024 - 4:51 AM
