> no power to anything..., after a hard rain
post Apr 5, 2008 - 6:57 PM
nightryder
Joined Sep 29, '05
From Rochester, Massachusetts
I have my underplastics off because I was trying to locate an oil leak. We had a good rain and I drove to school then work, no issues.
When I go to leave work, i turn the car to the "on" position, and then it just turns off. Like someone disconnected the battery. Now I can't get power to it. it wont pop start either.
I'm thinking something got wet that wasn't supposed to....
what do we think guys?
The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed?
post Apr 5, 2008 - 7:20 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
check the fuses, you probably did short something, but it shouldnt have shorted that easily. look for damaged or bare wires or loose connectors.
post Apr 5, 2008 - 10:24 PM
nightryder
Joined Sep 29, '05
QUOTE(Bitter @ Apr 5, 2008 - 7:20 PM) [snapback]661719[/snapback]
i did do a once over for connectors/wires and whatnot, next is fuses, thnx
post Apr 5, 2008 - 11:31 PM
95st-celica
Joined Mar 29, '07
From Philly
do fuses first...thats prolly your problem
1988 Dodge Aries K (sold)
post Apr 6, 2008 - 1:08 PM
nightryder
Joined Sep 29, '05
QUOTE(95st-celica @ Apr 5, 2008 - 11:31 PM) [snapback]661774[/snapback]
which fuse u think?
post Apr 6, 2008 - 3:06 PM
Bitter
Joined Mar 11, '06
QUOTE(nightryder @ Apr 6, 2008 - 1:08 PM) [snapback]661880[/snapback]
which fuse u think?
check them all, probably a larger one that feeds many circuits.
post Apr 6, 2008 - 4:05 PM
stevest202
Joined Oct 28, '07
From epworth uk
engine compartnent the oblong fuse box fuse 1 is 30amp starting circuit fuse 38 isa 40amp and controls electronic ignition the second of the two is a heavy duty type fuse could one of these
post Apr 6, 2008 - 4:46 PM
nightryder
Joined Sep 29, '05
ok i checked the fuses and they all look fine. Now the thing thats kind weird is I have no power to ANYTHING
I cant beep my alarm, lock the doors... when I turn the key to the "on" position, absolutely nothing happens.(ya know, normally the radio would come on and the idiot lights on the dash, but right now, nothing)
I forgot to check the ones under the dash tho, i didnt think they would be my issue, but ill check them anyway, and give another look at the other ones.
post Apr 6, 2008 - 5:14 PM
alltracman78
Joined Aug 9, '06
From Ma
If you have no power to anything, forget under the dash.
Check the large fuses in the main relay block.
They've got a clear top and look like boxes, they're not thin like normal fuses.
post Apr 18, 2008 - 3:21 PM
Rusty
Joined Nov 5, '07
From New Zealand
battery? battery connections?
post Apr 18, 2008 - 3:42 PM
D-Man
Joined Jan 18, '08
From Houston
QUOTE(Rusty @ Apr 18, 2008 - 3:21 PM) [snapback]665952[/snapback]
x2; if no electrical component has any power, the i'd check the battery and connections. maybe you lost a connection off your battery while driving; it wouldn't interrupt your driving at all, but after you turned it off you'd be SOL.
Damn D-Man - most impressive.
Lo-Fi Version Time is now: November 23rd, 2024 - 3:34 PM
