Enthusiast ![]() ![]() ![]() Joined Aug 19, '07 From Farmington, MI Currently Offline Reputation: 7 (100%) ![]() |
Hi, my passenger side front brake is always staying closed, after the first couple of times i brake, i can smell the brake on that side burning up and it makes my car wobble around, could this be the cause of a bad caliper, iw as gonna replace it tommorow, but brake pads are almost new, and rotor looks fine, just very hot and tired, can anyone help me out thanks
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 2, '05 From Guam Currently Offline Reputation: 15 (100%) ![]() |
Do you mean the caliper won't retract? the caliper is stuck? check the pistons etc....
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) ![]() |
yeah failing piston will do that. or something is stuck like a rock or something.
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) ![]() |
Most likely either the caliper piston is frozen [caliper] or the slide pins are frozen [caliper bracket].
Depending where you go to buy a caliper you might get just the caliper or you might get both. Usually both, just make sure before you buy it. Also, there is a slim chance something in the line or proportioning valve is causing this. 95^% of the time it's the caliper or bracket though. -------------------- ![]() |
Lo-Fi Version | Time is now: February 23rd, 2025 - 3:05 AM |
