> Is my clutch going?
post Apr 8, 2008 - 11:05 AM
airforceb2cc
Joined Feb 19, '08
From Missouri
Every morning when I take the kids to school and the car is cold, the car jerks (or stutters for lack of a better word) a few times when letting out the clutch. I usually let the clutch out around 1500 RPMs but it will still stutter at 2500-3000 RPMs. I don't think it is the engine as it still sounds like it is running fine. Once the car is warmed up and I have done a couple shifts or starts and stops it goes away. I have no idea if the clutch has ever been replaced.
Any ideas?
This post has been edited by airforceb2cc: Apr 8, 2008 - 12:14 PM
post Apr 8, 2008 - 11:22 AM
k-weaver
Joined Jun 5, '07
From Santa Maria
I am actually experiencing the same EXACT problem at the moment. I started a thread a while back ago and didn't get too many answers but everyone that did reply stated that it was the clutch.
So based off of my old thread I would say yes to the clutch.
post Apr 8, 2008 - 11:37 AM
purplegt4
Joined Feb 7, '03
From Northern Virginia
sounds like your clutch is chattering
take a look at this http://www.aa1car.com/library/2002/ic100237.htm
post Apr 8, 2008 - 12:13 PM
airforceb2cc
Joined Feb 19, '08
From Missouri
Chattering it is!! Hopefully it will last another 2 months to the engine rebuild.
post Apr 8, 2008 - 1:08 PM
99Celica
Joined Nov 1, '07
From Santa Barbara, CA
Wow that's a long list of things to inspect to see whats causing it. I started to have the same problem recently. If the car only does it when it's cold can we assume it's the clutch and not something external?
post Apr 8, 2008 - 2:46 PM
airforceb2cc
Joined Feb 19, '08
From Missouri
You can rule out just about everything but contamination and normal/abnormal wear with a quick visual inspection. I checked my mounts anyway but I was thinking along the same grounds in that if it isn't chattering all the time then it is probably an internal problem and not an external.
post Apr 11, 2008 - 5:40 PM
mr-belowaverage
Joined Feb 4, '07
From Ontario, Canada
QUOTE(airforceb2cc @ Apr 8, 2008 - 4:05 PM) [snapback]662516[/snapback]
What do you mean by this? You basically never rev match or what? This sentence makes no sense to me.
post Apr 12, 2008 - 7:56 AM
airforceb2cc
Joined Feb 19, '08
From Missouri
QUOTE(mr-belowaverage @ Apr 11, 2008 - 5:40 PM) [snapback]663706[/snapback]
When starting out in first, I let rev up to 1500 RPMs and let the clutch out.
post Apr 12, 2008 - 2:01 PM
6_GEN
Joined Feb 23, '08
From Indiana
I have the same problem,but when i replaced the intake back to stock it got a little better.....Not sure why,i guess i got more low end power to grab from lower rpm's where its less rotation.
post Apr 12, 2008 - 2:42 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
if you try it at lets say 2000 or 2500 rpm does it still do it?
post Apr 13, 2008 - 1:49 AM
vile_v
Joined Jun 16, '07
From Vancouver, Canada
I dont know if this well help you but a mechanic friend of mine told me this test to check for clutch slipping.
Try to start your car in 3rd gear while the handbrake is up. If you car stall suddenly that means your clutch is fine, but if you can keep going its slipping.
post Apr 13, 2008 - 9:44 AM
airforceb2cc
Joined Feb 19, '08
From Missouri
QUOTE(Bitter @ Apr 12, 2008 - 2:42 PM) [snapback]663932[/snapback]
Yeah...it will do it at any RPM.
I tried that test and my clutch isn't slipping but from what I've been reading, just because it isn't slipping doesn't mean it isn't worn. I have just over 150,000 miles on the stock clutch and I drive a bit aggressively so I think it has done its time.
Lo-Fi Version Time is now: November 23rd, 2024 - 7:58 AM
