> engine squeal during idle
post Apr 8, 2008 - 10:23 PM
A17322A
Joined Dec 19, '06
From San Francisco
Hey, i got a question that i hope some of you can answer for me. Recently, the car has begun to make some squealing noises during idle, it doesn't seem to happen when the car is revved or on a load. Also, this doesn't happen when the car is cold, (mostly when warmed-up), before this happened i changed the distributor cap and rotor (but i don't think this could have caused it... everything is tite and secure). Initially i thought it was the belts, but the sound doesn't seem like its coming from that side of the car, it sounds more like from the middle to driver side. The car drives normal and without hesitation (i've been driving on it for the last few days)
here is a video clip of it, hopefully it isn't something bad...
http://www.youtube.com/watch?v=CyhYfFkFpW0
Thanks everyone for the help and suggestions!
This post has been edited by A17322A: Apr 8, 2008 - 10:24 PM
95 celica ST
post Apr 8, 2008 - 10:52 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
sounds like a bearing, maybe idler or tensioner pulley bearing.
post Apr 9, 2008 - 12:58 AM
A17322A
Joined Dec 19, '06
From San Francisco
is it safe to just keep driving it? Do i need to repair it as soon as possible? or is it okay if i don't replace it?
95 celica ST
post Apr 9, 2008 - 2:30 AM
p0lish
Joined Apr 5, '08
From Warsaw, Poland
is that sound coming out of a cold or warm engine?
i get that sound when i just start the engine and the power steering transmission belt is loose
it does sound to me like one of the belts under your hod is loose, since when you step on the gas the squeal goes away
post Apr 9, 2008 - 2:43 AM
A17322A
Joined Dec 19, '06
From San Francisco
the sound is there when the engine is warmed up, so is it safe to just keep driving it this way (ie: till the belt gets pretty worn) or should i replace this as soon as possible
thanks for any more info/help!
95 celica ST
post Apr 9, 2008 - 2:58 AM
p0lish
Joined Apr 5, '08
From Warsaw, Poland
You need to know what exatly is causing the squeal. I can in no way give you a definite answer what is wrong withut seeing the car myself. If it is one of the transmission belts loose then it can be tighten or replaced. Costs are minor.
post Apr 9, 2008 - 5:21 PM
6G96GT
Joined Jan 20, '08
From East Coast
It's possible it "is" a belt even though you think it's not...probably powersteering belt loose like stated in the prior post...or maybe even the waterpump's on its way out.
This post has been edited by 6G96GT: Apr 9, 2008 - 5:22 PM
post Apr 9, 2008 - 5:30 PM
A17322A
Joined Dec 19, '06
From San Francisco
thanks for the help everyone, i'll try to see whats wrong with it sometime this weekend.
95 celica ST
Lo-Fi Version Time is now: January 11th, 2025 - 5:42 AM
