suspension and brake upgrade |
Apr 9, 2008 - 6:49 PM |
Enthusiast Joined Mar 22, '07 From Murphy, TX Currently Offline Reputation: 5 (100%) |
after some time of putting up with bad ride handling - i decided to replace and upgrade some parts to help the comfort.
Parts ordered - 1) EBC yellow brake pads -- $165 2) ATE PremiumOne rotors /fronts -- $85 3) Centric OEM quality Rotors / rears - $85 4) Control arms / Genuine Toyota -- $262.74 5) Energy Suspension / Sway Bar Bushings - front and rear - $45 6) Energy Suspension - Coil Spring cushions - $56 7) Stainless Steel Brake Lines / Magnum Performance - Ebay- Still waiting on shipment - $74 8) Royal Purple Synchromax tranny fluid and motor oil - $50 9) TRD Red Stitch steering wheel (already installed - will take picture later once everythings completed) - $650 10) Passenger side Ball Joint - $25 - Genuine Toyota 11) realignment - probably $60 Total so far -- $1495 So far only the control arms have been replaced. Took out the teins SS to clean and put on the cushions. Replaced inner axle boot on passengers side. Cleaned gunks from bottom of engine bay. The brakets for the bushings need to be modified to fit the bolt holes, so I'll finish modifying them tomorrow. Hopefully I'll finish installing everything else tomorrow if girlfriend doesn't come early. I plan on finishing tomorrow then get a realignment Friday. Here in Cleveland, OH most of the streets are horrible, so won't be lowering the celica any time soon, so I won't know how ride comfort will be with it lowered. After spending that much I better get some good results. Then once the brake lines come I'll have to work on it again. Next would be GT4 conversion and repaint. Oh - I also have some cusco front top mounts that I will be selling - so i'll post that in the FS section later. This post has been edited by 2bcelica: Apr 9, 2008 - 6:56 PM |
Apr 9, 2008 - 8:25 PM |
Enthusiast Joined Jul 31, '05 From Southern California Currently Offline Reputation: 7 (100%) |
if i had only waited a week or so... i just bought some cusco front mounts from japanparts.com
sounds like a pretty good list for upgrades all around -------------------- |
Apr 10, 2008 - 10:47 AM |
Enthusiast Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
wow that trd steering wheel is ~50% of what u spent.. must be damn comfortable.
nice setup! |
Apr 10, 2008 - 11:02 AM |
nice setup, you are going to enjoy some brake dust
Apr 12, 2008 - 5:14 PM |
Enthusiast Joined Sep 28, '07 From Toronto, ON Currently Offline Reputation: 5 (100%) |
I thought the EBC brake pads prevents brake dust...unless that's for Green Stuff only...what's the difference between Green and Yellow EBC brake pads?
This post has been edited by _mikeE: Apr 12, 2008 - 5:15 PM |
Apr 13, 2008 - 2:35 PM |
this thread is making me excited to order my stuff as well!
-------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Apr 13, 2008 - 3:51 PM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
wow true ballah status huh?? man your stacked on dough. lucky and good luck on the installs.
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Apr 13, 2008 - 4:19 PM |
no sway bars?
Apr 13, 2008 - 4:44 PM |
QUOTE(_mikeE @ Apr 12, 2008 - 10:14 PM) [snapback]663952[/snapback] I thought the EBC brake pads prevents brake dust...unless that's for Green Stuff only...what's the difference between Green and Yellow EBC brake pads? Yellow is Ultra high friction pads for race use but perfectly safe for street use. Red is Superstreet formula for cars above 200bhp and fastest street driving Green is Premium street sport pad for cars up to 200bhp. General spirited street driving. More info can be found at http://www.ebcbrakes.com/automotive.html |
Apr 13, 2008 - 4:53 PM |
QUOTE(808celica @ Apr 13, 2008 - 8:51 PM) [snapback]664197[/snapback] wow true ballah status huh?? man your stacked on dough. lucky and good luck on the installs. thanks - but because I use the celica for work and will be using it for lots of traveling - ride comfort was the priority on my list until I get a 2nd car. I know I could of ordered OEM quality stuff, but I just felt like spoiling myself for once QUOTE(LewFX @ Apr 13, 2008 - 9:19 PM) [snapback]664202[/snapback] no sway bars? I actually checked into that, but was already over budget. Eventually though -- Almost done with the install - would of been done already, but its been rainy and a bit cold - don't have an indoor garage - Just ordered two new Yokohoma S Drive tires for the rear, so I should be done with everything Wednesday This post has been edited by 2bcelica: Apr 13, 2008 - 4:56 PM |
Lo-Fi Version | Time is now: December 3rd, 2024 - 7:33 AM |
