> Heat shield, above muffler is loose
post Apr 10, 2008 - 2:05 PM
pepsiman
Joined Jun 3, '06
My heat shield (i think thats what it is) above my muffler is loose, when i close my hatch it makes a crappy vibrating sound. It is held in by odd fasteners. I have two in it, and one fell out completely and i replaced it with a bolt (that was very tricky, it didnt bolt into the frame like the rest seem to do, it had a sort of bracket coming down that i could use a bolt and nut with) I guess my question is how can i tighten us my loose fasteners to make it quit rattling, it has been bothering me. At first i thought they where star head but that didnt work. I dont think i could take a picture but i may go try. *edit pic added
This post has been edited by pepsiman: Apr 10, 2008 - 2:37 PM
post Apr 10, 2008 - 6:19 PM
A17322A
Joined Dec 19, '06
From San Francisco
maybe you can try to JB weld that thing on hah
95 celica ST
post Apr 12, 2008 - 7:11 AM
Hanyo
Joined Aug 16, '03
From Bay area
i think it is rivetted on to the body. I'm not 100% sure..
best way to fix this problem is to drill out the hole and run a new tap on there to get a new bolt installed. or you can just ripped the heat shield off. (something i would do smile.gif )
post Apr 12, 2008 - 6:04 PM
pepsiman
Joined Jun 3, '06
do i really need the heat shield?
post Apr 14, 2008 - 2:23 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Drive for a while, then check the interior of your trunk. It gets noticably warm over the muffler. It'd get quite a bit warmer, as in painfully hot, if you were to remove the heat shield.
Unlikely to be unsafe, but I hope you don't mind a hot trunk -- or an extra source of heat in your cabin.
Lo-Fi Version Time is now: January 11th, 2025 - 5:31 AM
