Car not starting! Help! |
Apr 10, 2008 - 11:00 PM |
Enthusiast Joined Jul 17, '07 Currently Offline Reputation: 1 (100%) |
How can you tell if your timing belt has broken? Will the car act like normal? or will the car run really crappy if the timing belt is broken?? 1996 Celica 7afe, The car has Air, has Spark, the only thing is I think the timing belt is broken, but prior to the car not starting, the car was driving perfect EXCEPT a check engine light.
One more thing, where is the fuel pump fuse?? If not a broken timing belt, I'm thinking it could be the fuel pump fuse, but where is it located? The car is cranking, just not starting, battery and alternator is fine, starter is fine. Any help would be appreciated, thanks! Car is at my work place and need to get it running a.s.a.p, thanks! This post has been edited by Cexlica: Apr 10, 2008 - 11:01 PM |
Apr 10, 2008 - 11:39 PM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
Maybe your fuel pump is out. Thats what happened to me and silly me I thought the timing belt broke. Just check to see if your fuel pump is out.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Apr 11, 2008 - 12:02 PM |
Enthusiast Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) |
x2 i just replaced a fuel pump, had a hole in it'd diaphragm. it happends~ i'd roll my dice at that, remove the line and see if it shoots out fuel when attempting to start it.
-------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Apr 11, 2008 - 12:11 PM |
uh, what was the CEL code?
I don't think the engine would crank if your timing belt was broken, IIRC -------------------- |
Apr 11, 2008 - 12:12 PM |
what is IIRC?
Apr 11, 2008 - 7:50 PM |
^IIRC stands for If I recall correctly and/or If I remembered correctly
Update: It is NOT the fuel pump, I have narrowed it down to 3 things, Fuel Filter, Clogged Injectors, Fuel pump relay fuse. <---Where is the fuel pump relay located in the fuse box??? Timing belt is fine. |
Apr 11, 2008 - 10:02 PM |
Look under the fuse box cover. It should tell you where it is.
Apr 13, 2008 - 9:00 PM |
I found the EFI relay, it's black, right? How do I tell if it needs replacing? It looks like all the wires are still entact.
Anyways, I just changed the fuel filter, and the car still does not start. I am completely stumped, i have no idea what is wrong now, the only thing i could think of are clogged injectors. But, the car was driving fine prior to not starting, shouldn't clogged injectors make the car run really crappy? Well, the car was driving fine before this happened. Once again, the fuel pump is working, fuel filter changed, timing belt is ok, air filter is ok, spark is ok, efi relay looks ok, battery is good. Car cranks but wouldn't start. No idea what the CEL could be, car was driving excellent even with the CEL came out, which was about 2 weeks before the car didn't start. Thanks!! This post has been edited by Cexlica: Apr 13, 2008 - 9:02 PM |
Apr 13, 2008 - 9:57 PM |
It could be your ignitor. I honestly don't think that your injectors are clogged to the point that the car won't start. You won't be able to tell if your relay is good or bad. You can find someone with a celica and use their relay and see if the car fires up. If you find out that that didn't help, it has to be something electrical. If the car was running fine before and all of the sudden decided to stop, I don't know. Take off the distributor and take the ignition control module to autozone and have them check out the ohms on that thing.
Apr 14, 2008 - 1:53 AM |
Enthusiast Joined Jun 16, '06 From Bowling Green KY Currently Offline Reputation: 7 (100%) |
what year is your car man?
-------------------- **If you play My Brute, joing the 6gc.net clan!**
--A section of a kid's actual test that had been scanned-- |
Apr 14, 2008 - 11:40 AM |
Enthusiast Joined Feb 4, '07 From Ontario, Canada Currently Offline Reputation: 0 (0%) |
Spray something combustible into the intake plenum and see if it catches for a minute. Check the fuel rails for pressure to rule out delivery.
Apr 14, 2008 - 12:12 PM |
Changing your fuel filter would not enable your car to start. I can't possibly imagine a fuel filter that could be so clogged that your car wouldn't start to begin with.
It sounds like you have an ignition problem. My bet would be a bad ignitor coil, dead distributor, or near-dead starter. Something like that. I'm not a mechanic though. What does your car sound like when you try to start it? Does it sound normal, but just doesn't catch? Or is there any kind of grinding sound? -------------------- |
Apr 14, 2008 - 2:31 PM |
QUOTE(mr-belowaverage @ Apr 14, 2008 - 11:40 AM) [snapback]664430[/snapback] Spray something combustible into the intake plenum and see if it catches for a minute. Check the fuel rails for pressure to rule out delivery. Yeah; like Nitroglycerin It's easyer to trouble shoot a problemed car that is spread across a few miles, because you know what you'll need. A new car. -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Apr 14, 2008 - 3:24 PM |
The car is in the shop at the moment, funny thing is the mechanic cranked it up and knew exactly what it was. I was like WTF, I was worrying for a whole week what the problem was, and here it took you 2 seconds to find the problem, lol.
It turns out to the the timing, the timing belt is still intact, but it jumped a couple teeth. |
Apr 14, 2008 - 3:32 PM |
oh, i hate when that happens... i sold a car because of that one time; when i was younger... only got like $150 bucks for it though for the shape of the car, i was actualy happy
Apr 14, 2008 - 4:03 PM |
Enthusiast Joined Nov 14, '06 From michigan Currently Offline Reputation: 10 (100%) |
QUOTE(Cexlica @ Apr 14, 2008 - 8:24 PM) [snapback]664498[/snapback] The car is in the shop at the moment, funny thing is the mechanic cranked it up and knew exactly what it was. I was like WTF, I was worrying for a whole week what the problem was, and here it took you 2 seconds to find the problem, lol. It turns out to the the timing, the timing belt is still intact, but it jumped a couple teeth. If it jumped once it will do it again. replace the belt and check the timing gears also. If they are worn replace them. |
Lo-Fi Version | Time is now: November 25th, 2024 - 11:27 PM |
