> 5sfe turbo kit?, just wondering
post Apr 11, 2008 - 2:45 AM
BeefyT
Joined Feb 19, '08
From Anaheim,CA
hey I googled 5sfe turbo kit and this came up....im just wondering if it works with the celica....or if its even worth it.
http://www.streetlevelperformance.com/Toyo...urbo%20Kit.aspx
This post has been edited by BeefyT: Apr 11, 2008 - 2:54 AM
lol
post Apr 11, 2008 - 3:32 AM
goferris
Joined Feb 14, '07
From Provo, UT USA
QUOTE(BeefyT @ Apr 11, 2008 - 1:45 AM) [snapback]663503[/snapback]
apparently the tk2501 is designed for the 5sfe but i wouldn't trust it. i would just piece together one using the notes from manny's (presure2) build. that's my plan. you could even just swap in a gen 2 3sgte for about that price.
post Apr 15, 2008 - 10:57 PM
6strngs
Joined May 12, '06
From Wilmington, NC
it looks ok for the most part actually. you'd need a fuel pump, and a 2 bar map sensor. you'd also need to run custom IC piping and need to get a custom exhaust made. also I'd ditch the "fuel controller" for a piggyback and have it tuned. plus you'd preferrably want some gauges too. and don't forget that the oil filter needs to be relocated. so, in the end, you could build a comparable kit for much, much cheaper than that. follow stuff from presure2's thread as goferris suggested.
post Apr 16, 2008 - 1:34 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Looks like it will only be good for low boost, until you upgrade the fuel management. I honestly think that if you piece your own parts together it will come out to be probably the same price, maybe cheaper and 10 time more reliable then that.
94 Celica gt white (sold)
Lo-Fi Version Time is now: November 27th, 2024 - 9:17 PM
