> Replaced radiator and rod bearings
post Apr 13, 2008 - 3:41 AM
BeefyT
Joined Feb 19, '08
From Anaheim,CA
I just got my car back from the mechanic. He replaced the radiator and the rod bearings. Everything seems to be running fine except when I take off in 1st gear. I can feel the pedals and and seat shake and the car seems to struggle taking off. It only happens for 2 seconds. Do you guys think it might be the clutch or something he did while replacing the rod bearings?
This post has been edited by BeefyT: Apr 13, 2008 - 5:46 AM
lol
post Apr 13, 2008 - 9:21 AM
6G96GT
Joined Jan 20, '08
From East Coast
Just to be sure, I'd check the injectors for any blockage, also check your motor mounts for wear, and possible check your timing...maybe the mech. advanced it a bit too much. I'd might check your intake hoses and pipes from the airmeter back to the throttle body to make sure everything's hooked up right and not loose or even disconnected.
post Apr 13, 2008 - 11:23 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
he replaced the rod bearings? and only the rod bearings? wtf mate. if your engine was damaged enough to need new rod bearings then odds are the crank should have been taken out, mic'd, turned, polished, and while you're at it do the main bearings as well.
thats like putting a plug in a bald tire, sure it works but you need a new tire. understand what i'm saying? i hate when shops just go for the quick and easy fix rather than doing it right. it makes me sound bad when i tell someone they need an engine because they have rod knock and they say 'well the shop down the road can do the rod bearings for $500 instead of the whole engine'. plugging a bald tire.
post Apr 13, 2008 - 12:18 PM
6G96GT
Joined Jan 20, '08
From East Coast
QUOTE(Bitter @ Apr 13, 2008 - 11:23 AM) [snapback]664116[/snapback]
Here's a scenerio for ya...if you ran a compression test on your block which is stock with 172K and the test ran a near perfect reading AND you don't burn oil, leak oil, or smoke at all...would you consider going into the bottom end and replacing the bearings "just because" of the high mileage? ... or would you leave it alone? I'm only asking cause that's my situation. SORRY TO INTRUDE ON THE POST!!!
post Apr 13, 2008 - 1:00 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE(6G96GT @ Apr 13, 2008 - 5:18 PM) [snapback]664129[/snapback]
compression and leaking oil has nothing to do with your bearings. all you HAVE to take off is the oil pan.
if it has a knock, i would
post Apr 13, 2008 - 1:15 PM
BeefyT
Joined Feb 19, '08
From Anaheim,CA
well he was just going to replace the radiator but he heard the engine was knocking so he just replaced the rod bearings so i wouldnt hear the knock. He told me the crank isnt damaged that bad. All he charged me was $250 US. He also did and oil change and replaced the spark plugs. Im gonna have the engine rebuilt soon.
lol
post Apr 13, 2008 - 2:18 PM
6G96GT
Joined Jan 20, '08
From East Coast
QUOTE(BeefyT @ Apr 13, 2008 - 1:15 PM) [snapback]664150[/snapback]
No, there's no knock and Oil Press. is perfect.
post Apr 13, 2008 - 7:27 PM
97lestyousay
Joined Jul 7, '03
So correct me if I am wrong. Mar 8 you posted about the rod bearing.
Then apr 1 about the radiator. Did you drive it with a spun rod bearing
JDM guy made me do it.
post Apr 13, 2008 - 10:47 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
i drove 60 miles w/ a rod knock and very little oil.
had to. mommy didn't know i left town.
i had just got my license/car. i was an idiot
This post has been edited by stephen_lee: Apr 13, 2008 - 10:49 PM
post Apr 14, 2008 - 3:16 AM
BeefyT
Joined Feb 19, '08
From Anaheim,CA
QUOTE(97lestyousay @ Apr 13, 2008 - 7:27 PM) [snapback]664236[/snapback]
yea i did drive it with a spun rod bearing.....but he said the crank wasnt damaged thats bad.....i dont know what "that bad" means....but im gonna rebuild the engine anyway.
lol
Lo-Fi Version Time is now: January 11th, 2025 - 10:36 AM
