Idle problems |
Idle problems |
Apr 15, 2008 - 3:08 AM |
Enthusiast Joined Sep 27, '07 From Tucson, AZ Currently Offline Reputation: 1 (100%) |
I've dug through a lot of the past topics on this through the search fuction, but thought I'd better get some others insight. Basically, my idle is just not consistant. When I start the car up cold, the idle will be about 100-200 RPMs too low (the car will shake/vibrate). Usually I'll warm it up by holding the gas down for a bit and usually the RPMs will rise to a mostly steady 800 RPMs. When driving at night my RPMs also suffer from having my low-beams/fog lights on (the idle is already taxed, and having the lights on adds to it). Lastly, having the AC on will greatly affect the RPMs. What usually will happen is that I'll be driving around town at 45 mph and then come to a light with the AC on and the RPMs will fall dramatically (below 500) and my car almost wants to die.....but then a few seconds later the idle will correct itself to somewhere near 800. This is fairly constant though, that is, whenever I come to a stop when having the AC on the idle drops far too low, but then corrects itself. Having said all that, the idle is perfectly fine at normal speeds. The only issue is when the car is stopped. Obviously, this is an annoyance and I would surely like to remedy the problem. Am I looking at replacing a coolant temperature sensor? The AIC? Any help is appreciated.
Apr 15, 2008 - 3:28 AM |
Your timing is off. Timing controls your idle, which initiates your AC clutch. I'm sure when your idle drops or picks up, you hear a click.
This post has been edited by trdproven: Apr 15, 2008 - 3:28 AM -------------------- 94 Celica GT
Apr 17, 2008 - 7:16 PM |
Enthusiast Joined Jan 20, '08 From East Coast Currently Offline Reputation: 1 (100%) |
Either that or altenator dying but trying to stay alive...
Apr 27, 2008 - 11:30 PM |
I'm not sure it's the timing because ignition timing would cause a loss of power, bad gas mileage, and overall terrible running condition. The car runs and idles fine once warmed up, but stumbles when cold-started and when running the AC.
May 5, 2008 - 12:21 AM |
QUOTE(trdproven @ Apr 15, 2008 - 3:28 AM) [snapback]664719[/snapback] Your timing is off. Timing controls your idle, which initiates your AC clutch. I'm sure when your idle drops or picks up, you hear a click. If I just sit at idle and have the AC on it will continually cycle on and off repeatedly. This happens about every 15 seconds. How come the ignition timing affects the operation of the AC? Your recommendation would be to adjust the base timing to correct this problem? |
May 5, 2008 - 4:46 AM |
Enthusiast Joined Nov 14, '06 From Northampton, UK Currently Offline Reputation: 5 (100%) |
I believe it could also be the Idle Air Control (IAC), which may just need a damn good clean. Can anyone else confirm this might be the cause?
This post has been edited by BloodyStupidDavey: May 5, 2008 - 4:46 AM -------------------- Davey
Items for sale |
Lo-Fi Version | Time is now: November 26th, 2024 - 7:48 PM |
