2 Pages V  < 1 2
> ST202 to 3rd gen 3S-GTE swap, After months of waiting and working hard the swap is almost complete
post Apr 22, 2008 - 1:57 PM
st202_turbo
Joined Apr 22, '08
From Northampton, England
Thank you very much corey, i think i will just have to drop a 3sgte motor in. my car has done over 120k miles so she does deserve a new motor.
Yeh i need to do some research on this.. like you said probably best to speak to someone who has made this swap, there are some questions only people who have made this swap will be able to answer..
A few that come to my mind are..
Does the 3sgte engine have to come from a celica Gt4 or can it be from a Mr2?
Will the st202 gearbox mate with the 3sgte engine?
Engine mounts? will that be an issue?
clutch?
Ecu?
If anyone has a 3sgte engine for sale please let me know.
omar
post Apr 22, 2008 - 2:20 PM
scothaniel
Joined May 1, '03
From Michigan
Omar,
It's probably better to ask those questions in a new thread, rather then hijacking this one. I've got the answers for all those questions!
Back to topic - Paul, thanks for the quick comparison. Were you able to find the axles lengths in the BGB?
Thanks,
Scott
Scott
West Michigan
post Apr 23, 2008 - 6:56 AM
Paul_Celica_GT
Joined May 20, '06
From Netherlands
Yes I did,
Standard axle lengths:
5S-FE/3S-FE (M/T):
Left: 572,4 +/- 5,0 mm
Right: 857,5 +/- 5,0 mm
7A-FE:
Left: 559,2 +/- 5,0 mm
Right: 854,9 +/- 5,0 mm
3S-GE w/ LSD (E56):
Left: 573,2 +/- 5,0 mm
Right: 861,5 +/- 5,0 mm
3S-GE w/o LSD (S54):
Left: 576,2 +/- 5,0 mm
Right: 863,8 +/- 5,0 mm
I don't know the MR2 standard axle lengths, because in the MR2 Factory Manual they use different reference points. The length that's measured in the Celica BGB is the whole axle w/o the entire last part that goes in the wheelbearing, so not only the splines but w/o the entire piece.
My swap has been completed, I just driving around with it right now. I'm very happy about it. I hope to continue the story soon.
Converted JDM '98 GT-Four to LHD, check my site: Celica GT.nl
post Apr 23, 2008 - 1:32 PM
scothaniel
Joined May 1, '03
From Michigan
So do these lengths include the splines going into the trans?
Scott
West Michigan
post Apr 23, 2008 - 4:01 PM
Paul_Celica_GT
Joined May 20, '06
From Netherlands
Yes, it's this length:
post Apr 23, 2008 - 4:32 PM
scothaniel
Joined May 1, '03
From Michigan
Awesome, thanks a lot!
Scott
West Michigan
post Jun 12, 2008 - 5:25 AM
Paul_Celica_GT
Joined May 20, '06
From Netherlands
Time for an update!
PART 2: Maintaining the 3S-GTE engine
After I pulled the 3S-GTE engine from the GT-Four, it was time for some maintenance. I replaced the following parts:
    • Timingbelt with rollers
    • V-belt
    • V-belt powersteeringpump
    • Clutch, including pressureplate and bearing
    • Spark plugs
    • Fuel filter
    • Engine Oil and Oilfilter
    • Coolant
    • Intercooler Coolant (Toyota Longlife Red)
    • Gearbox oil
    • Brakefluid (DOT 3 or better)
    • Clutch fluid (is the same as brakefluid)
Beside these replacement parts you also need two things that aren't on the RHD GT-Four nor my LHD ST202:
    • Hood lock, LHD, ST205, part nr. 53510-20510, EUR 63,48 inc taxes
    • Accelerator cable *, LHD, ST205, part nr. 78180-2D310, EUR 155,90 inc taxes
*Note: the length of the Accelerator cable is the same for the ST202 and ST205, only the protection is at other places
Some of the replacement parts
Timingbelt
I removed the crankshaftpulley bolt using this special tool, though it's easier to loosen the bolt when the engine is still in the car tongue.gif
Upper cover removed
Engine mount removed, you kan see the green tensioner clearly now
Mounted new timingbelt, timing is exactly the same as before
Placed the covers back on and installed a (new) crankshaft pulley, the old one was damaged during removal unfortunately
Clutch
Before you can access the clutch the gearbox has to come off. Since I can't use the E154 gearbox, it needed to come off anyway. Be aware that the gearbox is heavy (40 - 50 kg). Don't drop it on your toe's like I did. Fortunately I weared workboots.
Removed the gearbox
Removed the pressureplate and the frictionplate. The flywheel was still ok
Cleaned the new pressureplate with brakecleaner
Mounted the pressureplate with the frictionplate in it on the flywheel. Used my eyes to center it
After the E56 transmission was removed, I changed the release bearing
Sparkplugs and valvecover
During replacement of the sparkplugs I found out that the valvecovergasket was leaking, because there was oil in the sparkplugshafts.
Removed the valvecover
Oil in the sparkplug shafts
Cleaned the oil out and replaced the sparkplugs
Installed valvecover with new gaskets
After all the maintenance was completed I pulled the 3S-GE engine from my ST202. See part three for that.
post Jun 12, 2008 - 8:40 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
awesomepictures, but yes i would have kept the 205. any chance you can send the chassis to me in California?
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
2 Pages V  < 1 2
Lo-Fi Version Time is now: December 1st, 2024 - 5:24 AM
