> Compressor Surge, good or bad
post Apr 16, 2008 - 9:28 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
http://www.youtube.com/watch?v=LZUbo_mNDZM
ive read many debates of whether or not this is good for the turbo.
i first heard it on the ken nomuras blitz skyline and thought it was the blitz bov. i was wrong haha
i love the sound to death
エキサイティングカーレーシングチーム!
post Apr 16, 2008 - 10:00 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
well its bad for the turbo and performance.
slows the turbo down between shifts = more lag
eventually harms the bearings = oil leaks and turbo failure
not really anything good about it other than the sound, thats why higher end turbos are made with anti-surge housings, also to avoid spool up surge where the turbo trys to feed more air into the engine than it can take. pretty much same process as compressor surge just at different time.
post Apr 17, 2008 - 11:45 AM
alltracman78
Joined Aug 9, '06
From Ma
Yeah, who the hell told you it was good?!!!
It sounds kind of nifty, but that's it.
post Apr 22, 2008 - 9:12 PM
jesterwr217
Joined Feb 27, '07
From cape coral/ft myers florida
compressor surge=bent or broken shaft
BOOST GETS YOU LAID!!!!
post Apr 22, 2008 - 9:16 PM
If loving you is wrong.... I don't want to be right.
post Apr 22, 2008 - 9:57 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
a little bit is fine, much like those s13's on those vids is bad.
if you have a bov, and want flutter (surge) wind the bov reasonably tight, so it only goes off at say 3 psi and higher, but below that you get combined flutter and bov, you dont wanna sound like the ghey et pulsar and other shi!t little ricer cars that have bov going off every 5 seconds.
This post has been edited by Cuts_the_Pilot: Apr 22, 2008 - 9:58 PM
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Apr 23, 2008 - 1:27 AM
Insanity-74
Joined Jan 9, '05
From Under the car
My car has been making that noise now for two years or more...more so than on that video.....have had no problems with the turbo at all and I`m running 20psi...although I am running the airfilter more or less directly on the turbo which dosnt do anything to deaden the sound.
post Apr 23, 2008 - 7:34 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
my bov flutters LONG after the bov goes off. only because the turbo is still spinning for so long and still pushing alot of air biggrin.gif sounds like a supra.
post Apr 23, 2008 - 8:17 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
i looked it up earlier and there was a debate on the topic. i love the sound
エキサイティングカーレーシングチーム!
post Apr 23, 2008 - 8:37 AM
The basic idea is that its bad. Thats why you are supposed to install a blow off valve. In reality, it will take a long time before you do any damage to your turbo because of it.
post Apr 23, 2008 - 10:03 AM
Rayme
Joined Feb 18, '06
From NB, Canada
I thought about it...
under normal operation, you have the exhaust side of the turbo pushing the turbing, and on the other side, you have the impeller compressing air. That normal condition alone apply a twisting force to the shaft.
During "surge" you have the impeller being slowed down by air, and the exhaust side somewhat spinning freely because of lack of throttle plate opening..that also apply a twisting force to the shaft.
So..is it really that bad? Certainly for performance as it slows the turbo when the throttle plate closes but damage the turbo?
The 5th gen all-trac has no bypass valve, and alot more cars (mostly older ones) and turbos have been around for decades.
Myself I don't think compressor surge is all what it's cracked up to be. All turbos are going to die before the engines itself.
This post has been edited by Rayme: Apr 23, 2008 - 10:09 AM
-Rémy
02 SiR, 08 250R
post Apr 23, 2008 - 10:06 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
over time, yes. i don't know the "time" though. kinda like the rapture.
air is thicker than you think.
post May 2, 2008 - 9:16 AM
mrgt4
Joined Mar 27, '08
From england
i get massively loud compressor surge when i let off the throttle slowly, not done mine any harm so far... but only been running it as said for around 2k miles
1994 ST-205 JDM GTFour... fmic conversion finshed, project GT500 is underway
www.rising-sun-racing.com
tuning , performance, repairs and conversions... Blitz, TRD and many more suppliers :)
post May 2, 2008 - 1:00 PM
alltracman78
Joined Aug 9, '06
From Ma
QUOTE(Rayme @ Apr 23, 2008 - 10:03 AM) [snapback]667314[/snapback]
Twisting isn't the big problem, that force is applied in the same direction, which isn't as bad.
You have the compressor spinning at somewhere near 100,000 RPMs [under high boost], when you have surge you have pressurized air shooting back at the compressor blades, trying to force them in the opposite direction.
This fatigues the compressor blades.
It works similar to how rod bolts stretch at higher RPMs, though that is a much more extreme example.
It's not going to break the turbo the first time it happens, or the tenth, or probably the hundredth, but it most definitely will weaken the turbo to some extent. How much depends on how bad the surge is and how often you do it.
It's never a good thing.
post May 5, 2008 - 6:01 PM
pitcelica
Joined Jan 28, '07
From Québec, Canada
My car is doing this sound. But I have a Greddy type-RS installed. How can it happen? Can I test my BOV? If yes, how can I do that? Thanks
Lo-Fi Version Time is now: February 22nd, 2025 - 2:32 AM
