> OIL LEAK!
post Apr 16, 2008 - 9:57 AM
butterdog
Joined Dec 8, '05
From South Bend / Mishawaka INDIANA
Got my usual oil change today and I was told that my oil was really low. I asked if it had a leak and they said there's a very slow one not coming from any lines or anything, but oil is on the bottom of the engine. Any others have problems like this? Any suggestions/solutions before I take it to a toyota specific shop?
post Apr 16, 2008 - 10:16 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Our cars are known to leak from the front seals. That could be yor problem, because thats the problem I had. See I don't know the correct term for the front seal, its just what my dad called it and the shop also called it too.
94 Celica gt white (sold)
post Apr 16, 2008 - 10:27 AM
D-Man
Joined Jan 18, '08
From Houston
knowing that, i'd jack it up, get it on stands, and with the brightest flashlight you got, Try to find the point of origin. That way, you know what it is, or we could tell you with provided pictures.
Damn D-Man - most impressive.
post Apr 16, 2008 - 10:39 AM
Sinyk
Joined Oct 4, '06
From Kelowna, BC Canada
Oil switch maybe? Mine went and was leaking really quickly.
post Apr 16, 2008 - 11:01 AM
airforceb2cc
Joined Feb 19, '08
From Missouri
A very common thing to go are the front and rear main seals (the seals around the crank). Look at your CV boots and see if they have oil on them. Also, check the inside of your front rims for oil. Usually once main seals start to leak, it will be a slow leak until you change them. I'd make it a good habbit to start checking your oil every time you fill up or every Sunday...whichever comes first. Start looking from the bottom of the oil pan and move up slowly to see where the oil stops...that should give you an idea of what may be going.
Another thing you can do is push down on your dip stick holder...those can come loose.
post Apr 16, 2008 - 3:29 PM
QUOTE(airforceb2cc @ Apr 16, 2008 - 12:01 PM) [snapback]665111[/snapback]
the main seals where are they. I know where the rear one is, inside the cluthc but not the other one
post Apr 16, 2008 - 5:07 PM
alltracman78
Joined Aug 9, '06
From Ma
On a high mileage 5S, anywhere.
I don't believe the 96 got the better HG yet, so from the top
Valve cover gasket
Dist
Cam seals
Head Gasket
Front main seal [basically in the oil pump].
Oil pump
Rear main seal
Oil pan
If it's not enough to leave drips on your parking spot it's probably not that bad a leak.
You could have burned the oil as well.
post Apr 16, 2008 - 6:57 PM
6G96GT
Joined Jan 20, '08
From East Coast
Still got good oil pressure? Some shops can put a harmless dye in the oil and then pretty quickly locate the leak.
post Apr 17, 2008 - 3:00 AM
butterdog
Joined Dec 8, '05
QUOTE(6G96GT @ Apr 16, 2008 - 6:57 PM) [snapback]665356[/snapback]
Oil pressure is still good, everything is running fine. That's why it was such a surprise. I do notice I have a couple oil spots where I park at night but definately not a pool.
post Apr 17, 2008 - 9:26 AM
nightryder
Joined Sep 29, '05
From Rochester, Massachusetts
its a UV dye. You clean up the oil on your engine. put the stuff in the crank case, drive it for a while then jack it up and use a black light to see where the oil is coming out of
works pretty well actually
The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed?
post Apr 17, 2008 - 7:13 PM
6G96GT
Joined Jan 20, '08
From East Coast
If it were me, I guess I'd get the dye to find it...other than that, try to find it soon.
post Apr 18, 2008 - 10:13 AM
butterdog
Joined Dec 8, '05
I brought your suggestions in and got it checked out...
Apparrently a LOT of stuff went bad.
Valve Cover Gasket, Cam Seal, Distributor O Rings, Oil Pump, Crank Seal, Oil Pan Gasket.
Anyone need a kidney?
post Apr 18, 2008 - 11:22 AM
airforceb2cc
Joined Feb 19, '08
From Missouri
Just make sure you aren't getting hosed and they are replacing every seal that holds oil in the engine.
post Apr 18, 2008 - 1:00 PM
foutong
Joined Feb 6, '08
From portland or
had my leak from the valve cover gasket. it turns out the people who did the tune up didnt tighten it all the way and i could literally loosen it with my fingers
post Apr 18, 2008 - 1:44 PM
QUOTE(butterdog @ Apr 18, 2008 - 11:13 AM) [snapback]665867[/snapback]
post Apr 18, 2008 - 4:37 PM
6G96GT
Joined Jan 20, '08
From East Coast
So what are you going to do? That sounds like a pretty expensive fix.
post Apr 19, 2008 - 1:14 PM
trdproven
Joined Aug 2, '05
From Guam
QUOTE(alltracman78 @ Apr 16, 2008 - 5:07 PM) [snapback]665300[/snapback]
Valve cover gasket
Dist
Cam seals
Head Gasket
Oil pump
Rear main seal
Oil pan
These are good ideas.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: November 30th, 2024 - 4:12 AM
