> Konis
post Apr 17, 2008 - 11:56 AM
94TRDcelica
Joined Feb 4, '08
From UK
Hi! I got Koni's all round at the mo, but the front drivers side is shot (Adjuster jammed and then started leaking oil) so i took it out and replaced the cartridge with an OEM for the moment (I got it real cheap).
Can I just replace the one strut and be ok?
The rears are absolutely fine as far as I am aware and the front passenger side is still good!
post Apr 17, 2008 - 12:13 PM
you should actually be able to send your blown KONI into them and have it rebuilt
post Apr 17, 2008 - 12:42 PM
94TRDcelica
Joined Feb 4, '08
From UK
Just got off the phone to them - its out of Warranty! And they reckon I should get both fronts, but im usure if that was just sales talk! wink.gif
The shot shock was first noticed when I was adjusting and the adjuster got jammed and then I notcied the oil, its been getting worse since then! This was around 7months ago!
I guess I could just buy the one, and when i instal it I'll take the other side out and check it out for wear!!!! and then decide!!!
post Apr 17, 2008 - 1:00 PM
even out of warranty its still cheaper to buy a new one than to get it rebuilt? dang that sux frown.gif
post Apr 17, 2008 - 1:12 PM
94TRDcelica
Joined Feb 4, '08
From UK
Yeah! But still my question remains - Is it viable to just replace the faulty one or do i definately need to do both at the same time?
post Apr 17, 2008 - 1:13 PM
just the one side should be fine.
post Apr 17, 2008 - 1:34 PM
94TRDcelica
Joined Feb 4, '08
From UK
post Apr 18, 2008 - 5:24 AM
Dell
Joined Feb 4, '07
From Ireland
It's good practice to change both sides, same with springs. Old and new don't perform the same. That's in an ideal world anyway and he has to say that to cover himself if anything happened. But if you can't stretch to buying two don't worry too much about it.
Lo-Fi Version Time is now: January 10th, 2025 - 8:54 PM
