Compression test results |
Apr 17, 2008 - 6:11 PM |
As stated, i ran a compression test on my Daily. the red Celica.
OK, So the results are:
Any feed back on the results? -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Apr 17, 2008 - 6:20 PM |
Enthusiast Joined Jan 31, '07 From Ontario, Canada Currently Offline Reputation: 1 (100%) |
I dont think those are very good numbers, mine I checked a couple months ago where:
190-191-190-192 |
Apr 17, 2008 - 7:53 PM |
run 1/2 can seafoam in the engine oil, 20 minutes at idle then change the oil. recheck compression.
Apr 17, 2008 - 8:38 PM |
Enthusiast Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
did you crank the engine until the needle on the gauge wouldn't go up any further. it usually takes 2+ compression strokes or so for it to register completely.
Apr 17, 2008 - 10:08 PM |
i've already ran seafoam in the gas/oil and through the intake. and i cranked it until the needle stopped movin, then a few more. Engine was warm.
although i didn't do the 'add a few drops of oil to each cyl' thing -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Apr 18, 2008 - 10:58 AM |
Enthusiast Joined Jan 16, '07 From covington, KY Currently Offline Reputation: 9 (77%) |
QUOTE(stephen_lee @ Apr 18, 2008 - 3:08 AM) [snapback]665737[/snapback] i've already ran seafoam in the gas/oil and through the intake. and i cranked it until the needle stopped movin, then a few more. Engine was warm. although i didn't do the 'add a few drops of oil to each cyl' thing adding oil to each cylinder is called a wet compression test. what you want to look for with a wet comp. is comp. drop |
Lo-Fi Version | Time is now: January 12th, 2025 - 2:15 PM |
