questions for 2.5" exhaust owners |
Apr 18, 2008 - 12:23 PM |
Enthusiast Joined Jul 29, '03 From north of detroit Currently Offline Reputation: 6 (100%) |
i'm installing a 2.5" exhaust on my gt soon (muffler and pipe in hand) but i had a couple questions for people who have run the same size. first, did you buy/make an adapter to bolt right up to the header, or just use a slip-on/clamped/welded reducer coupling?
second...can anybody post pics of their set-up? i'm not really interested in the kind of muffler you have or the way it sounds, i just want to see how other people have routed the pipe. thanks! -------------------- do you know who i am, mr. worley? |
Apr 19, 2008 - 1:32 AM |
Enthusiast Joined Dec 20, '07 From Valkeakoski, Finland Currently Offline Reputation: 0 (0%) |
QUOTE(uberschall @ Apr 18, 2008 - 12:23 PM) [snapback]665912[/snapback] i'm installing a 2.5" exhaust on my gt soon (muffler and pipe in hand) but i had a couple questions for people who have run the same size. first, did you buy/make an adapter to bolt right up to the header, or just use a slip-on/clamped/welded reducer coupling? second...can anybody post pics of their set-up? i'm not really interested in the kind of muffler you have or the way it sounds, i just want to see how other people have routed the pipe. thanks! Dont know about your engine, what kind of gains youŽll be gettin', but on the 3S-GE it doesnŽt actually make no difference at all, wether it starts from header or if its just a catback. And yeah, route it like the original one? Then you should be able to use the original clamps. -------------------- |
Apr 19, 2008 - 12:52 PM |
Enthusiast Joined Apr 15, '07 From Fort Worth, TX Currently Offline Reputation: 12 (100%) |
Be sure to run a cat and resonator along with your piping so it doesn't sound ricey. I did this on my N/A Supra and that car purred.
-Matt |
Apr 20, 2008 - 8:20 AM |
QUOTE(GotToyota @ Apr 19, 2008 - 12:52 PM) [snapback]666211[/snapback] Be sure to run a cat and resonator along with your piping so it doesn't sound ricey. I did this on my N/A Supra and that car purred. -Matt Does the resonator make the sound lower? Or what, Im confused -------------------- |
Apr 21, 2008 - 5:21 PM |
judging by the responses/ lack of, i'm assuming no-one has made a bolt-up adapter.
my exhaust is broken and i need to fix it, i am planning to do a complete new exhaust in the next year or so, i just wanted to see what options were there. for now, i'm going to run stock size back the the axle, and then 2.5" into a 2.5" magnaflow. janky, yes. expensive, difficult, or time-consuming...no. autocross season is upon us, and i've got to get legal. thanks for the input. -------------------- do you know who i am, mr. worley? |
Apr 21, 2008 - 6:24 PM |
Enthusiast Joined Feb 16, '06 From Maui, Hawaii Currently Offline Reputation: 6 (100%) |
Here's a few old pix of my exhaust setup. Sorry about the dirty under carriage.
What I did since my downpipe was originally cut (engine swap), I cut off about 2" of the celica's OEM downpipe that normally bolts down to the rear of the crossmember. Doing it this way still leaves me a 2" exhaust flange to the rear and original location of the O2 sensor on the downpipe like how it was before. Anyways, I had an exhaust shop weld the cut downpipes together with a 2" piece of piping (You can see it from the first pic). Now from the rear of the downpipe the exhaust shop welded a 2" exhaust flange with reducer on the front of the magnaflow cat converter and also a 2.5" exhaust flange on the rear of the cat converter and then bolted them accordingly (2nd pix). This way I can still unbolt the cat. converter from the exhaust whenever I want but most importantly so I can just unbolt the whole downpipe from the entire custom cat-back system instead of cutting and rewelding it all over again. Then from the rear of the cat. converter the exhaust shop did a 2.5" piping all the way to the rear muffler (over-axle including a 2.5" in/out magnaflow resonator in the mid-section of the piping (2nd and 3rd pix). -------------------- |
Apr 23, 2008 - 11:46 AM |
awesome netrata, thanks!
Apr 23, 2008 - 1:52 PM |
Enthusiast Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) |
Apr 23, 2008 - 4:09 PM |
Hey elvasoshexai, could you please make a vid on how your exhaust sounds like. I'm actually thinking a similar setup with the 2.5" piping and going under-axle instead of what I have now.
Lo-Fi Version | Time is now: January 11th, 2025 - 1:27 AM |
