> Brake light, brake light troubles
post Apr 19, 2008 - 3:44 PM
Gnaredge
Joined Jun 11, '07
From St. Louis
Recently my brake light started coming on when i would brake during driving, but will stop when its warm outside. which is not a problem just means im going to have to change my brakes i just havent gotten around to it. but my question is why is my brake light coming on when im shifting between gears?
post Apr 19, 2008 - 9:37 PM
alltracman78
Joined Aug 9, '06
From Ma
It doesn't necessarily mean the pads are low.
Make sure your fluid is topped off, check the pad thickness [They're supposed to be replaced at 1mm].
If it's neither of these your fluid level switch is probably bad. It's part of the master cylinder cap.
post Apr 20, 2008 - 1:25 AM
Gnaredge
Joined Jun 11, '07
From St. Louis
Alright ill check that stuff out. thanks for the help
Lo-Fi Version Time is now: January 11th, 2025 - 4:46 AM
