wiring problem |
wiring problem |
Apr 20, 2008 - 9:08 PM |
Enthusiast Joined Dec 18, '05 From pittsburgh Currently Offline Reputation: 0 (0%) |
i have installed a 6 disc cd player in my car, i got it from my familys van and when it was removed from the van the company got lazy and just cut the power wire (battery, ignition and ground). i hooked the battery and ignition wires up to fuses temperarily. i was wondering where i can tap into to get a wire connected to the battery and a wire connected to the ignition so that when i turn the car off the cd player turns off as well.
if you have any ideas or know where i can tap into those wires ..... plz either pm me or respond here as to where the wires are located and colors (if known) thanks ~TC~ |
Apr 21, 2008 - 1:21 AM |
Enthusiast Joined Apr 11, '08 From clearwater Currently Offline Reputation: 0 (0%) |
where are you mounting it?
Apr 21, 2008 - 8:12 AM |
QUOTE(-mo- @ Apr 21, 2008 - 1:21 AM) [snapback]666550[/snapback] where are you mounting it? i have it mounted in the trunk but the wires are ran into the engine |
Apr 21, 2008 - 2:43 PM |
i would have said to go behind the radio if you were unsure on the wiring, but since you are in the bay already im sure you can find something there. unfortunately, i cannot advise which wires to tap. however, i would recommend you run an inline fuse with your constant to the changer. and even if someone gives you a wire to tap, id still check it with a probe or meter.
Apr 21, 2008 - 4:28 PM |
Enthusiast Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
Just hook it up like you would an amp: Ign to the blue/white stripe wire from the aftermarket HU, 12v [+] constant to the battery via a fuse and [-] to a good unpainted metal object in the trunk [Hatch/Trunk latch work well.]
Hope this helps -------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Lo-Fi Version | Time is now: November 25th, 2024 - 5:43 PM |
