help please: fast blink turn signal removal |
Apr 21, 2008 - 12:03 AM |
Enthusiast Joined Apr 11, '08 From clearwater Currently Offline Reputation: 0 (0%) |
hello all,
i cant figure out how to get my turn signals to a regular blink...im pretty sure it has a hyper blink relay or something of that nature installed, but i cannot find it. all of the bulbs are working and there are no electrical problems that im aware of. any help would be appreciated...im kinda sick of the ricey blinker...thankfully, that is the last of the ricer performance mods that is left on the car... -mo- |
Apr 21, 2008 - 12:10 AM |
Enthusiast Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
maybe not grounded?
Apr 21, 2008 - 1:20 AM |
QUOTE(purplegt4 @ Apr 21, 2008 - 12:10 AM) [snapback]666516[/snapback] maybe not grounded? i think if that were the case, they would not work. besides, that would be in the cars harness which seems to be intact...im fairly sure its an aftermarket thing...just need to know where to look...thks tho... |
Apr 21, 2008 - 4:46 AM |
Enthusiast Joined Oct 28, '07 From epworth uk Currently Offline Reputation: 3 (100%) |
QUOTE(-mo- @ Apr 21, 2008 - 12:03 AM) [snapback]666511[/snapback] hello all, i cant figure out how to get my turn signals to a regular blink...im pretty sure it has a hyper blink relay or something of that nature installed, but i cannot find it. all of the bulbs are working and there are no electrical problems that im aware of. any help would be appreciated...im kinda sick of the ricey blinker...thankfully, that is the last of the ricer performance mods that is left on the car... -mo- it sounds like you just need to replace the flasher unit yours seems to be faulty ill see if i can find the position for you -------------------- |
Apr 21, 2008 - 6:11 AM |
Enthusiast Joined Aug 3, '07 From Bellevue, Nebraska Currently Offline Reputation: 28 (100%) |
check to make sure LEDs weren't used in the external flashers. i had these in a 98 neon and it caused the fast blink.
-------------------- ~Andy
Check out my Droid Goodies | My Flickr |
Apr 21, 2008 - 2:47 PM |
thks, ive been trying to find the flasher control relay....but no luck. good idea in the bulbs, ill check that. its unlikely as the signals themselves are stock but its definately worth a shot....any info on flasher location would be good. thks again.
-mo- |
Apr 21, 2008 - 4:41 PM |
inside the fuse box under the dash (at least in JDM models it is), it's a big (usually) green or black 3 prong box relay. no way to tell if it's bad. look at the diagram on the fuse cover, if it's not there, check the fuse box under the hood near the battery. pull it and go to auto zone and ask for a new one. once you get it, take it to your car and put it in. if that doesn't fix the problem, USUALLY they accept returns on stuff that doesn't fix your problem.
Apr 21, 2008 - 4:44 PM |
Left kick panel, up near the top left corner of it.
Put the turn signal on while you're looking for it, you should hear it clicking. -------------------- |
Apr 21, 2008 - 4:53 PM |
Enthusiast Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
QUOTE(stetsonaw @ Apr 21, 2008 - 4:41 PM) [snapback]666736[/snapback] inside the fuse box under the dash (at least in JDM models it is), it's a big (usually) green or black 3 prong box relay. no way to tell if it's bad. look at the diagram on the fuse cover, if it's not there, check the fuse box under the hood near the battery. pull it and go to auto zone and ask for a new one. once you get it, take it to your car and put it in. if that doesn't fix the problem, USUALLY they accept returns on stuff that doesn't fix your problem. Good method but you'll need to pretend it doesn't fit the same - if they know you've tried it they won't take it back [all electrical parts nowadays] QUOTE(alltracman78 @ Apr 21, 2008 - 4:44 PM) [snapback]666742[/snapback] Left kick panel, up near the top left corner of it. Put the turn signal on while you're looking for it, you should hear it clicking. Good to know - that work for most relays? -------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Apr 21, 2008 - 4:59 PM |
I'm bettin' you have a bulb out, myself
Apr 21, 2008 - 9:31 PM |
good idea about putting the turn signal on then looking for the relay...its so simple, i didnt even think about it...wow...ill do tomorrow and let you guys know...im pretty sure its not any bulbs as they all work...i think its that damn relay...thks
-mo- |
Apr 23, 2008 - 6:48 PM |
I have a funky connection on my FR turn signal, sometimes it bumps "loose" or something and I get that fast click-click-click that sounds like tiny rabbits humping in my gauge cluster. Then I'll drive over a bump and it'll return to normal. Be sure to check your bulbs when you hear the bunnies.
Apr 24, 2008 - 2:46 AM |
ive been through the whole gambit...i give up...ricey ricey baby...im good...thanks all....
Lo-Fi Version | Time is now: November 25th, 2024 - 5:47 PM |
