> Fuel gauge problem, Help plz
post Apr 21, 2008 - 9:04 PM
mikecelica
Joined Jan 31, '07
From Ontario, Canada
I broke the little sewing needle thing inside the cluster for the fuel gauge, by accident when I was installing my glow gauges. What can I do, can I get just that needle thing, Im not talking about the needle that shows how much gas you have i mean it looks like an actual sewing needle and its inside a little motor that moves it, it snapped in half. If I buy a cluster from someone, can I use just that piece or do I have to replace the whole cluster? If i do that, then i would have different mileage on the new cluster? Anyone been in this situation plz help Im so lost... thanks
This post has been edited by mikecelica: Apr 21, 2008 - 9:04 PM
post Apr 21, 2008 - 9:10 PM
mikecelica
Joined Jan 31, '07
One other thing, is there such thing as an external fuel gauge you can buy? Just like a boost gauge or oil pressure gauge that you can put in a pod? Anyone know wwere to get one? thanks alot for any help,, realy appreciate it
post Apr 21, 2008 - 9:39 PM
GreenyST204
Joined Apr 11, '06
From Tasmania
Im sure you are able to remove the indapendent gaugee from the main cluster so the revs are one the speedo is two and the temp and fuel are three the just unscreew from the back of the cluster.
Ok Gladys, lets play house, you be the door and I'll shut you.
post Apr 21, 2008 - 10:15 PM
QUOTE(GreenyST204 @ Apr 21, 2008 - 10:39 PM) [snapback]666850[/snapback]
correct. Just buy another cluster and swap the section you need.
post Apr 21, 2008 - 11:02 PM
mikecelica
Joined Jan 31, '07
ok thanks alot.
post Apr 22, 2008 - 9:30 AM
mikecelica
Joined Jan 31, '07
Does anyone know where to get an aftermarket external fuel gauge? Anyone ever done this before, is it alot of work? thanks
Lo-Fi Version Time is now: December 1st, 2024 - 6:34 PM
