> Problems with a power Stering Pump, Need some Facts.
post Apr 22, 2008 - 3:29 PM
D-Man
Joined Jan 18, '08
From Houston
Okay, so my PS pump was installed by it's previous owner kindasad.gif Now the problem here is that it's been leaking.
I just keep filling it up, but people are bitching about it; so it needs to get fixed.
I got ahold of the previous owner; and some mention of "The standard washers are not installed, its just 2 grounding connections being used for washers" was mentioned. frown.gif WTF?!
now i'm looking at this happy blue-print (thanks to much SEARCH function wink.gif You guys would be astonished how much you can learn using it laugh.gif )
Now my photoshop wont save when i try to highlight the part, but you see that big black diamond? Says "Gasket" next to it? I think this is where the problem could be.
My question is this Is there anywhere else that "2 washers" go; or could go, that would cause a leak (in the power steering fluid) when improperly installed? Rather it be farther down the line or farther up, Is there any other place i could expect to be leaking due to these "washers"?
Thanks guys.
This post has been edited by D-Man: Apr 22, 2008 - 5:00 PM
Damn D-Man - most impressive.
post Apr 22, 2008 - 3:42 PM
D-Man
Joined Jan 18, '08
From Houston
Also, I cannot find this gasket from toyota... they have no idea what i'm talking about... Any idea's on what to use to close this thing off?
(i'm thinking Copper washers would flex into place about right; while maintaining the stregnth to not break or bend...)
post Apr 22, 2008 - 4:16 PM
QUOTE(D-Man @ Apr 22, 2008 - 4:42 PM) [snapback]667126[/snapback]
hey i think thats the same gasket as the ones in the brake lines, in the calipers...
toyota world has a seal kit
Seal kit, celica, gt - power - POWER 95-99 $38.73 $29.43 maybe? IDK
post Apr 22, 2008 - 4:35 PM
D-Man
Joined Jan 18, '08
From Houston
Pricey for a freakin washer/gasket kindasad.gif
Thanks though; i'm waiting for their e-mail to find out if it has what i need biggrin.gif
post Apr 22, 2008 - 4:53 PM
QUOTE(D-Man @ Apr 22, 2008 - 5:35 PM) [snapback]667142[/snapback]
i think its the whole seal kit, it might or not include the aforementioned gasket/ if that is what you are looking for...
post Apr 22, 2008 - 4:59 PM
D-Man
Joined Jan 18, '08
From Houston
i'll see when they mail me back.
Probably wouldnt hurt to do all seals seeing as this dude obviously didnt have a clue.... Grounding connectors as washers? confused.gif For sealing pressurized fluid? confused.gif confused.gif
WTF?!
post Apr 22, 2008 - 5:43 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Black RTV in a pinch?
Washers could be on any of those bolts. I'd lay $ it's the washers on the two long bolts labled 440 and 400. But then again that other one w/the black diamond does attach an actual hose, so you might be right. Clean off the pump housing as best as possible and then run it, see where it's leaking from.
Maybe pull all three bolts out and see if you can find the Mysterious Grounding Connections and use RTV as a temporary fix when you put the bolts back in?
post Apr 23, 2008 - 9:01 AM
D-Man
Joined Jan 18, '08
From Houston
Na, The 440 & 400 just hold the pump itself to the bottom of the engine. Otherwise would be a good bet. No fluid flows there.
It could be on some of the other hoses, but it looks like those ring clamps are placed there, therefore a washer would be a waste. ALso, i know all those hoses there are rubber-ish. (don't know the exact DNA strand compound, but there' rubber-ish laugh.gif )
What are you going on about RTV? I got my boss to let me slide till the weekend; and me and one good friend will probably end up with the task, (he knows zero about celicas too kindasad.gif ) but he taught me alot about cars when i was younger.
I was thinkin of pullin that bolt out of the presure line, taking it down to Ace hardware or something, and finding something that would deff connect, and toping it off with some of that black super hard silicone tar schett i use on auto glass. I figure Just a dap on the outer flat of the washer should ensure that perfect seal.
but if i dont find theese infamous grounding connections there on that high pressure line, then DEFF going on a hunt for them till i find em.
I'm gunna towel dry everything before heading over to my buddy's place (witch ever buddy i can find first honnestly tongue.gif ) but that way i'd have a double check by following the fluid leak.
Thanks for the input griff.
post Apr 23, 2008 - 10:23 AM
Paul_Celica_GT
Joined May 20, '06
From Netherlands
The part nr. of the gasket that you mean in the first post is 44327-30030 according to the EPC. That's for the 94-95 models, I don't know if it's different in later years.
Converted JDM '98 GT-Four to LHD, check my site: Celica GT.nl
post Apr 23, 2008 - 11:02 AM
D-Man
Joined Jan 18, '08
From Houston
QUOTE(Paul_Celica_GT @ Apr 23, 2008 - 10:23 AM) [snapback]667328[/snapback]
(i hope you win the lottery for being such a big help tongue.gif )
And i'm sporting that ever so beautiful 95 model so it sounds just perfect.
post Apr 23, 2008 - 12:16 PM
alltracman78
Joined Aug 9, '06
From Ma
That gasket is basically 2 metal crush washers joined together. It's probably what they're talking about.
You don't want to use any silicone on it, there's somewhere north of 1,000 PSI in the high pressure side. It will blow that stuff out.
Use the right gasket.
Just FYI, depending what he replaced the pump with [used, or even worse, his own rebuild], it could also be the pump shaft seal, rear seal, high pressure line, or one of the low pressure ones.
You might want to do some investigating as to what exactly is leaking first.
That gasket is probably the same for any S [or MZ] pwr steering pump from 86 to 06. If the P# is different, it will probably work anyways.
This is why I'm not always a big fan of people fixing their own cars.
So many times people half ass things, either because they're cheap, they don't care, or they just don't know any better.
And then when they sell it, it's "engine rebuilt 10,000 miles ago", or "brakes just done", yet they neglect to mention that they did all the work, it was their first time, and it's only going to last another 5,000 miles.
I know there are many of you that do know what you're doing, or are capable of learning and doing it right. I started by working on my own car too. The problem is, there's just too many idiots out there.
In all fairness, there are mechanics and shops that are morons too, I just wanted to vent. smile.gif
post Apr 23, 2008 - 12:41 PM
D-Man
Joined Jan 18, '08
From Houston
post Apr 23, 2008 - 2:28 PM
D-Man
Joined Jan 18, '08
From Houston
Paul_Celica_GT; thanks again. My local toyota dealer has 16 in stock. I'm picking on up today after work. biggrin.gif
post Apr 23, 2008 - 4:08 PM
Paul_Celica_GT
Joined May 20, '06
From Netherlands
No problem man. Just helping out, hope it's this gasket that's leaking. Just FYI: it's a bitch to get to it on the 3S-GE/3S-GTE engine, but with the 7A-FE you probably have more space.
@Altraccman78: I know what talking about. My swap was the first I did, but I used the BGB on the side, and only used OEM parts or better. And some mechanics really suck, others are great.
post Apr 23, 2008 - 4:20 PM
D-Man
Joined Jan 18, '08
From Houston
nope, installin on the 5s-fe; and it looks like it's going to be a b!tch. biggrin.gif
But I only have to do it once. wink.gif And I intend to only do it once tongue.gif
This post has been edited by D-Man: Apr 23, 2008 - 4:21 PM
post Apr 23, 2008 - 4:29 PM
Paul_Celica_GT
Joined May 20, '06
From Netherlands
Oops. forgot about the 5S-FE, hehe, here in Holland we've only got the AT200, ST202 and ST205. Sorry 'bout that tongue.gif Good luck with the gasket change.
Lo-Fi Version Time is now: January 11th, 2025 - 9:11 PM
