> push start
post Apr 24, 2008 - 1:44 PM
stevest202
Joined Oct 28, '07
From epworth uk
some one gave me the start button so went to local garage bought a 40/30 amp relay some 18gauge and 12 gauge wire and fitted today will change the button shortly to one them with stat illuminated blue cos these look crap but heyho it works biggrin.gif
post Apr 24, 2008 - 2:09 PM
manphibian
Joined Oct 13, '06
From UK
Cool, you got it sorted.
Now if you're like me you'll use it 5 times, then NEVER again! :lol:
I forget it's there now.
post Apr 24, 2008 - 2:15 PM
mikecelica
Joined Jan 31, '07
From Ontario, Canada
Is it hard to do? Is there a kit for it or you have to piece it together yourself? And will it work with manual trans? thanks
post Apr 24, 2008 - 2:18 PM
stevest202
Joined Oct 28, '07
From epworth uk
it will work on any mate i made mine up as button was given to me but you can buy kits off ebay
post Apr 24, 2008 - 2:49 PM
i tought you had to push your car, to start it. Figured it was a bad starter. laugh.gif laugh.gif
JK, d you have to have the key in place?
post Apr 24, 2008 - 2:58 PM
stevest202
Joined Oct 28, '07
From epworth uk
QUOTE(njccmd2002 @ Apr 24, 2008 - 2:49 PM) [snapback]667769[/snapback]
yes it would be too easy to pinch if not you can still use key as normal its just a bit of fun
post Apr 25, 2008 - 10:29 AM
Culpable04
Joined Apr 17, '06
From New Jersey
I had one on my 4th gen, but the only reason why I got it was because the ignition switch was bad and it wasn't sending current to the starter, so that was my cheaper way out of it.
what's the convinience ? I mean you have to put the key in and turn it, and then push a buttom ? that's adding steps to a simple process.
post Apr 25, 2008 - 11:29 AM
manphibian
Joined Oct 13, '06
From UK
QUOTE(Culpable04 @ Apr 25, 2008 - 4:29 PM) [snapback]668029[/snapback]
QUOTE(stevest202 @ Apr 24, 2008 - 8:58 PM) [snapback]667775[/snapback]
post Apr 25, 2008 - 11:39 AM
Culpable04
Joined Apr 17, '06
From New Jersey
fun for some YES, I was talking about convinience. We all do stuff that doesn't make much sence to our cars, and as long as you like it that/s fine, but that was just my opinion., not a good one but that's mine.
post Apr 25, 2008 - 11:54 AM
D-Man
Joined Jan 18, '08
From Houston
Opinions are like.... tongue.gif ... push-button starter switches.
well... not really...
But clean install, i have to give you props for that.
Damn D-Man - most impressive.
turboman23
Joined Jan 25, '08
From Topeka, KS
i got one in my car and i like it better than turning the key. mine bypasses the neutral safety switch so i just got to put the key in and push the button. and it also helps with security. my buddies got ahold of my keys one day and tried to take my car for a joy ride but they didn't know how to start it laugh.gif laugh.gif
1st car- 1994 Celica GT 2.2L 5s-fe SOLD
2nd car- 1995 Celica ST 2.0L 3s-gte SOLD
Current car- 1996 Z28 Camaro 5.7L LT1
post Apr 25, 2008 - 11:55 AM
DEATH
Joined Dec 19, '07
From tx
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Apr 25, 2008 - 12:02 PM
D-Man
Joined Jan 18, '08
From Houston
out of curiosity, do you guys intersect with the starter lines inside near the key hole, or under the hood?
I tryed to steal my car the other day, but the shaft off of the key hole is massively long...
This post has been edited by D-Man: Apr 25, 2008 - 12:03 PM
post Apr 25, 2008 - 1:11 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE(turboman23 @ Apr 25, 2008 - 11:54 AM) [snapback]668071[/snapback]
iit also helps with security. my buddies got ahold of my keys one day and tried to take my car for a joy ride but they didn't know how to start it laugh.gif laugh.gif
Exactly why I have mine. I had a friend at work try to steal mine the other day and park it in the other parking lot to fcuk with me but he couldn't - he does this to me all the time. rolleyes.gif Seriously dude - the jokes getting old and nobody drives my car. Ever.
EXT: WRC/TRD/404
post Apr 25, 2008 - 1:30 PM
vincent_doggy
Joined May 25, '06
From Hong Kong
I got one from PIVOT price is fair, for TRD one, nice but just ask 2 much
post Apr 25, 2008 - 2:20 PM
stevest202
Joined Oct 28, '07
From epworth uk
QUOTE(D-Man @ Apr 25, 2008 - 12:02 PM) [snapback]668074[/snapback]
its easy as the connector block is close to front of barrel and wired as per diagram
post Apr 25, 2008 - 2:27 PM
D-Man
Joined Jan 18, '08
From Houston
lol, thanks, but i meant how do you access the wires on the 6gc, i'm used to poping the ignition cover and viola, there is the ignition wiring.
Psycialy, where do you access the wires?
post Apr 25, 2008 - 2:39 PM
stevest202
Joined Oct 28, '07
From epworth uk
QUOTE(D-Man @ Apr 25, 2008 - 2:27 PM) [snapback]668127[/snapback]
when you pull the cowl down to reveal behind ignition and your looking at barrel you see the large white connector for the barrel itself its the thick red/white and black/white that where i connected i see what you mean now
post Apr 25, 2008 - 2:56 PM
D-Man
Joined Jan 18, '08
From Houston
Okay, so the ignition is in the massly long tube, and that's what your refering to: "Barrel"
And it can be unclipped and pulled out enough to get behind the key-ignition peice from the front? B/C i couldn't figure it out the other morning... I figured i'd have to crawl up by the petals and and decided not to because i couldn't make out the wire coloring.
post Apr 25, 2008 - 3:03 PM
stevest202
Joined Oct 28, '07
From epworth uk
QUOTE(D-Man @ Apr 25, 2008 - 2:56 PM) [snapback]668138[/snapback]
no mate if you take the cowl under steering down the one surrounding fuse box at the side of long tube near th front you will see it alot easier if you want to do it i will photo for you to point it out biggrin.gif
Lo-Fi Version Time is now: February 20th, 2025 - 11:48 AM
