> Cup Holders to Ipod Holder, A how to guide, lots of pictures
post Apr 26, 2008 - 2:49 PM
Legit94GT
Joined Feb 6, '08
From Oregon
Well i am doing a stereo system build in my car and rather than have my ipod cable get put into my glove box i wanted something a little more custom, so it came to me one day when i was cleaning that i might be able to fit my ipod in where the cup holders are. This also keeps your ipod from rattling around in the eglove box and cause more scratches. So i got my i pod(one of the 2nd gen ones that are twice as thick as the one today) and it looked like it would fit so now that my build is going down in a week i had to get started on it. So i will try to explain everything good...
You will need:
A philps screw driver
A small hole saw, aka a jib saw(or a hack saw blade)
A file
Sand paper
A peice of something to make the base. I use a peice of 3/16x3.5 in Aluminium and cut and sanded it down to size. Be carefull not to go with something to thick other wise the ipod wont fit inside the armrest.
Any type of contact cement or appox will work, if the base plate is sanded to be a tight fit.
Narrow strips of rubber matting
First start by un screwing your armrest. there are two screws that hold the arm rest to the center console. There are six screws that hold the plastic peice to the arm rest. Once the plastic piece is off you can see how to remove to actual cup holders peice. If you have a vice to hold the part in use it, but be carfull not to over tighten it or you will break it. Start by cutting out the middle peice with the small saw or blade. try to stay away from the edge on the first you cuts then work your way in.
Next you need to unscrew the latch. You will need to cut off the plastic tab that the latch screws into. This will remove the latch, but even with the latch gone there is no play in the armrest anyway.
Then comes the sanding and filing to make everything nice and smooth on the inside of the cup holders, some more cutting maybe required. Once you are satisfied with that you need to fit whatever you have decided to use as the base. I used some aluminum and cut it to the right length on a bandsaw. Now you can use whatever material you feel like, diamond plate, wood, plastic, whatever just as long as it is rigid enough to hold the weight of your Ipod. Once it was the right length i took it to a belt sander to sand it down to the right width to fit into the bottom of the cup holders. Once i got it to the right width, where it would just barely fit in i took it over to the polishing wheel to clean it up a bit.
With my base plate sized and clean i got out the appoxy and rubbed it all on the sides. Then i clamped it all together for 15 mintues to let it set up. I would advise you to follow whatever your adhesive tells you to, some require you to wait a long time.
I then glued the rubber onto the sides of the cup holders. NOTE: when you remove the center cup holder plastic peice it is not solid, it is hollow and when you sand it to the outside frame it will look bad. you can sand it all the way down then paint it or do whatever you want, this is just what i did.
Once everything is set up you are ready to put it back in your car. The I pod cable will fit on top ot the base plate and under the plastic, BUT you need to cut a slot here... So that the cable can run into the tray.
I wont get into wiring as i am not doing any, but once the cable is wired to your head unit you will need to run in under your shifter then cut a slot into the armrest compartment to run the cable, be sure the Ipod cable is secured so it wont fall down and get mixed up with the shifter cables and everything else. Once it is ran through your center console just run it into you new tray and plug in your Ipod smile.gif Alot of newer deck let you control your whole ipod through your Head Unit, if yours does that then you can just keep your ipod in there and not worry about it, i dont know any body who is going to rip off the cup holders when they are stealing a car lol
Once you are done putting it all back together just sit back and enjoy:)
1 JL 1,000/1v2
2 JL 12" W6v2
2 Focal 6.5 component 165a1
Kenwood DDX512 head unit
Running 142.6db with the back seat up:)
post Apr 26, 2008 - 2:57 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
haha thats clever
エキサイティングカーレーシングチーム!
tonytutino
Joined Jun 16, '06
From Bowling Green KY
good work, this is wicked. if i were you though man i'd try to to do something to the rubber strips due to the rough-looking edges. for a cleaner install. maybe its just the pictures but at a glance it just looks like scratched paint.
but again props!
post Apr 26, 2008 - 3:16 PM
DippedInSauce
Joined Nov 1, '06
From The Bay, CA
nice job! i wanna consider this biggrin.gif i hate my cupholders
post Apr 26, 2008 - 4:38 PM
Legit94GT
Joined Feb 6, '08
From Oregon
QUOTE(tonytutino @ Apr 26, 2008 - 2:57 PM) [snapback]668430[/snapback]
but again props!
ya the rubber isnt what i wanted but it will do for now untill i can get the right stuff...
nice job! i wanna consider this i hate my cupholders
Ya i hated mine too they were always in the way when you shift, so i cut that stuff out of there!!!!
1 JL 1,000/1v2
2 JL 12" W6v2
post Apr 28, 2008 - 12:54 AM
DippedInSauce
Joined Nov 1, '06
From The Bay, CA
this is mine. i just got done doing it, i used clear plastic for the bottom. i must say... this is an "anti-theft" device biggrin.gif hehe
thanks for the idea, legit. its really nice!
This post has been edited by DippedInSauce: Apr 28, 2008 - 12:55 AM
post Apr 28, 2008 - 1:25 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I was going to do this about a year ago when I got my Nano. I would have only had to trim a small amount fromthe first cup holder to make it fit. Would've been much better, as it would have retained cup holder functionality.
**** Photobucket
post Apr 28, 2008 - 1:53 PM
markjbutler
Joined Sep 27, '07
From Devon, UK
post Apr 28, 2008 - 8:22 PM
punkuup5150
Joined Apr 10, '07
From lodi, ca
i was thinking abotu doing this also but i wanted to try and do it in the armrest like fiberglass it in with my cord that connect to the deck since im plannign on getting a touchscreen that controlls all of the fuctions of the ipod but i have to wait till my goverment check shows up to do it hopefully within the next month
post May 1, 2008 - 6:43 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
QUOTE(punkuup5150 @ Apr 28, 2008 - 6:22 PM) [snapback]669083[/snapback]
http://www.irs.gov/irs/article/0,,id=180250,00.html
That'll give you a better idea of when to expect it
post May 2, 2008 - 9:43 AM
Legit94GT
Joined Feb 6, '08
From Oregon
QUOTE(punkuup5150 @ Apr 28, 2008 - 8:22 PM) [snapback]669083[/snapback]
Yup i am running the cable under the armrest to my deck (see my other post) and that way i can just leave it in the tray and not worry about it cause you can run every thing from the screen:)
To bad i wont get my check till like july!!!! oh well
1 JL 1,000/1v2
2 JL 12" W6v2
post May 11, 2008 - 10:22 PM
jussten
Joined Oct 31, '03
From Phoenix, Az
That is a pretty cool idea, I used to just put mine(before I lost it) in the trey under my deck and the cord comes out of a hole I drilled in the back of the trey. But accessing it wasn't as easy as it would be there. I thought About turning the lighter plug into a holder but never got around to looking into it.
post May 29, 2008 - 5:38 AM
ej8ferio702
Joined Apr 23, '08
From VEGAS
looks good just clean up the edges and your done
post May 29, 2008 - 9:11 AM
ra65_22re
Joined Aug 21, '06
From washington
Thats awsome! I need to do this. I just throw my ipod in the armrest. How will u run the cable to the ipod? R u goin to keep it in the cupholder when ur using it? I prob goin to do this and look at where to put some cupholders 2.
post May 29, 2008 - 10:30 AM
Legit94GT
Joined Feb 6, '08
From Oregon
QUOTE (ra65_22re @ May 29, 2008 - 10:11 AM) *
My deck controls my ipod so when it is hooked up i dont have to touch the ipod, i really only have to even pull it out and remove it when i want to put new songs on it...
Honestly i never use cupholders so i didnt have a problem tossing them, but if you use them alot you might want to keep them... alot of cars now put the cup holder in the bottom part of the door, maybe you could make a custom holder down there?biggrin.gif
To run the cable you just.... read the how to forum located
/\ smile.gif
l
l
I totally did that arrow wrong... i lack keyboarding skills lol
This post has been edited by Legit94GT: May 29, 2008 - 10:33 AM
1 JL 1,000/1v2
2 JL 12" W6v2
Lo-Fi Version Time is now: November 22nd, 2024 - 8:11 PM
