> Is there any ECU mods i can do to my car??, Can I wire anything into my ecu
post Apr 26, 2008 - 6:01 PM
ninjapimp
Joined Apr 26, '08
From NJ
My friend has a car where we opened up the ecu and wired some component into it and it gave the car an incredible amount of horse power.... So i was wondering if there is anything similar i can do to my 94 st hatch?? please help...
post Apr 26, 2008 - 6:04 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
the Apexi SAFC is the only thing id ever plug into my ecu. if you want to go all out you can go wiht the greddy e-manage. all of this is to tune the engine tho. im not sure what ur buddy put in his car
エキサイティングカーレーシングチーム!
post Apr 26, 2008 - 6:23 PM
ninjapimp
Joined Apr 26, '08
From NJ
so by adding one of these.... it does what... how do i get hp exactly by adding this? and where would i get one
post Apr 26, 2008 - 6:38 PM
mikecelica
Joined Jan 31, '07
From Ontario, Canada
APEXi SAFC II
Piggyback Fuel Computer
Modifies air-flow meter signal (pressure signal in some vehicles) to optimize fuel-air ratio; Vacuum Fluorescent Display (VFD).
The second-generation SAFC is a fuel computer that adjusts fuel/air ratio by modifying the air-flow meter/MAP sensor signal. The SAFC features a user-definable, eight-point, adjustable fuel curve that can be set in 500 RPM increments. The range of fuel adjustment is +/- 50% at each of the user-defined setting points. On hot-wire vehicles, the Deceleration Air Flow Correction function is capable of curing the erratic idle and stall problems associated with open-atmosphere blow-off valves on hot-wire air-flow meter systems. The SAFC is capable of monitoring and replaying the following data channels in Numerical, Analog Meter and Graph displays: Intake Manifold Vacuum/Boost Pressure, Air Flow Capacity, Intake Manifold Pressure, Karmann Frequency, Engine RPM, Throttle Position, and Air Flow Correction %.
http://www.6gc.net/forums/index.php?showtopic=57871
I've got one for sale, bought it for my car but I need to sell because I need the money to buy brakes. Its an Apex-i Super AirFlow Converter 2nd Edition. Safc2. Check it out let me know if your interested.
This post has been edited by mikecelica: Apr 26, 2008 - 6:43 PM
post Apr 26, 2008 - 6:49 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
there u go!
エキサイティングカーレーシングチーム!
Lo-Fi Version Time is now: November 29th, 2024 - 3:55 PM
