> Gas leak???, from exhaust?
post Sep 3, 2003 - 12:56 AM
chosen1
Joined Nov 20, '02
From Chicago to Boston and back to Chicago
I've noticed just recently that when I get out of the car that there is a strong smell of gas coming from the car. Today, I smelled gas coming strongly from my muffler. Sometimes it even smells while I'm driving. There are no leaks coming from under the car though. Is this normal???
post Sep 3, 2003 - 10:10 PM
No thats not normal, your absolutely sure you dont have any leaks?
post Sep 3, 2003 - 11:06 PM
macavely
Joined Nov 4, '02
do you have problems while driving.. like do you have power loss?
post Sep 6, 2003 - 4:57 AM
chosen1
Joined Nov 20, '02
I'm sure that nothing is leaking from underneath the car. I can't tell about power loss because I just put an intake on and its driving differently. What should I do. I think it only does this when I drive long distances. What do you guys think?
post Sep 6, 2003 - 5:38 AM
edo17982
Joined Dec 21, '02
From Italy
smile.gif check the fuel pump
This post has been edited by edo17982: Sep 6, 2003 - 5:39 AM
edo17982
Joined Dec 21, '02
From Italy
If you have a little leak it's not necessary that u can see it on the ground...follow the gas line from the fuel railto the filter with your hand and look if it's wet...if it is, check if it smell of gas...if yes you found the leak wink.gif
Lo-Fi Version Time is now: December 1st, 2024 - 5:39 PM
