> Camber Kit, Crash bolts.
post Apr 28, 2008 - 2:11 PM
I got new tires today, and went to the dealer to get alignment. They todl me they would not do it because just by looking at the tires they said i needed camber kits.
Judging by the looks of the wheel, you can tell it has a little neg effect; and looking at the old tire, only the rears show different wear.
Im running teins, KYB. I know each car is different. Ive read about crash bolts, what are those and where to find them.
I found these kits are they good.
http://www.tirerack.com/suspension/suspens...nded+Align.+Kit
any suggestions welcomed.
post Apr 28, 2008 - 2:17 PM
Culpable04
Joined Apr 17, '06
From New Jersey
didn't they tell you that they sell those bolts for ~ US$6.00 a peice ? what kind of stealer did you go to,
BTW I have those same bolts on the link, but honestly you can get the same bolts from the dealer, the part number is somewhere around here.
post Apr 28, 2008 - 2:19 PM
a) why did you go to a dealer
b) on that setup you should be able to get an alignment perfectly fine.
post Apr 28, 2008 - 2:39 PM
i always align there, dont trust anyone else in macon.
The dealer said they dont have the bolts for my car, unless they dont know what it is. they offered at first, said they had them but then declined, and told me they were wrong.
And honest to good just by eyeballing, you can tell there is negative camber. take a look at the pic, the orange thing is a level bar in pic 2. You can tell the difference.
Now if i get the kit, i dont seem ti find why some are +/- 1.oo degree and why others state +/- 1.75, they are the same brand.
I would like to have the ones from toyota, but i dont have part numbers... Are they any different. Oh and i dont really dont want to undo my teins. Yes I desperately need spacers.. wink.gif
from tirerack
Front or Rear Fitment
Note: Camber adjustment +/-1.0
Manufacturer Part #: 5.81270K
from importrp
Part number 5.81270K\8
10/1989-1999 TOYOTA, Celica, GT/ST, Incl. Turbo, Coupe, Cnvrtbl & Lftbk, Exc. All-Trac ST18/ST20 Chassis
Rear +/- 1.75 degrees of adjustment.
Front +/- 1.75 degrees of adjustment.
This post has been edited by njccmd2002: Aug 9, 2011 - 12:05 PM
post Apr 29, 2008 - 9:23 AM
i will be buying today.
is it 2 pairs, 1 for front and 1 for back, right? each wheel gets one?
post Apr 29, 2008 - 10:35 AM
FYI (some) negative camber is ok and doesn't always effect tire wear. Toe will eat a tire to bits rather fast though.
My car ran ~1*+ or so of negative camber....handling FTW (negative camber increases cornering abilities, too much will decrease braking)
This post has been edited by playr158: Apr 29, 2008 - 11:21 AM
post Apr 29, 2008 - 11:13 AM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE(njccmd2002 @ Apr 29, 2008 - 9:23 AM) [snapback]669215[/snapback]
only front ( 1 pair )
post Apr 29, 2008 - 3:07 PM
only the front? But the back looks more messed up. Nobody wants to align without camber kits.... kindasad.gif
post Apr 29, 2008 - 5:14 PM
Jared95
Joined Apr 24, '07
From lufkin tx
so i went to a guy and for $55 he put my camber bolts in and aligned the only deal was that it was so out of alignment from my wreck they couldn't get it to stop pulling.??
what's the next step because i know my frame had no damage.
sorry to jack your thread....
This post has been edited by Jared95: Apr 29, 2008 - 5:15 PM
post Apr 29, 2008 - 5:18 PM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE(njccmd2002 @ Apr 29, 2008 - 3:07 PM) [snapback]669317[/snapback]
the back can be adjusted, camber bolts are only needed on the front
post Apr 29, 2008 - 6:31 PM
alltracman78
Joined Aug 9, '06
From Ma
Front and rear are both adjustable to a point without adding parts. Exactly how far depends on the car.
Whether it needs them depends how far you're out.
You might only need them on one wheel.
QUOTE(playr158 @ Apr 29, 2008 - 10:35 AM) [snapback]669229[/snapback]
QUOTE(Jared95 @ Apr 29, 2008 - 5:14 PM) [snapback]669367[/snapback]
Could be caster or camber, I can't tell you without looking at the car, though a pic of the specs the car is at now would help.
post Apr 29, 2008 - 7:27 PM
QUOTE(alltracman78 @ Apr 29, 2008 - 7:31 PM) [snapback]669393[/snapback]
post Apr 29, 2008 - 9:12 PM
go somewhere else
post Mar 22, 2010 - 4:23 AM
whatthe
Joined Aug 13, '08
From Australia
QUOTE (Culpable04 @ Apr 30, 2008 - 9:18 AM) *
QUOTE (njccmd2002 @ Apr 29, 2008 - 3:07 PM) *
This statement is wrong. Front camber can be adjusted, rears can not. And need camber bolts.
post Mar 25, 2010 - 2:39 AM
chacha
Joined Dec 29, '05
From So-Cal
i need help on this too...my back is really messed up after putting up the ksport coilovers...what is the recommended for the fronts camber and the rear?
njccmd2002, if you have these in, please take a pic and please please show where it goes and how to install.
This post has been edited by chacha: Mar 25, 2010 - 2:45 AM
post Mar 25, 2010 - 3:00 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
When i did my alignment they got me at -0.9 on the front and -1.2 on the back, thats in the green zone they have set on the computer. Thats with a Tein Spring drop (1.5" FR 1" RR). Now Im about 3.5" down on all 4 and I've set my camber to lets say -0.75 FR and -0.5 RR with hardly any tire wear, so let's say I hit the jackpot on good camber wink.gif
post Mar 25, 2010 - 4:41 PM
best ive got
post Aug 9, 2011 - 12:12 PM
for those who have asked me..
these are the camber bolts, and are easy to install....
with them in the box..
out of the box...
basically remove the upper one with a bar..
then try to guess where you want it placed...
i made some marks as to remove most camber possible i just guessed...
once i placed the bolt then it was just a matter of aligning the marks...
then i had
of course, this was eyeballed...
then i had it aligned...
post Aug 9, 2011 - 1:15 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
I have the same set up without camber bolts and they alligned it no problem.
I don't understand how these can adjust camber lol
My Celica!
post Aug 9, 2011 - 8:04 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (jordisonjr @ Aug 9, 2011 - 8:15 AM) *
seriously though, once you put them on and spin them in either direction you'll see how it works
Lo-Fi Version Time is now: January 9th, 2025 - 6:29 AM
