2 Pages V  < 1 2
> Camber Kit, Crash bolts.
post Aug 9, 2011 - 8:30 PM
celica-s
Joined May 9, '11
From Manila, Philippines
been using same camber bolt design for sometime now but with another brand. it works.
the bolt is actually a cam. when you twist it you'll get the low and the high profile. that's your camber adjustment range.
post Oct 9, 2011 - 3:43 PM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
I have been having the same problem with my tien-s springs. I don't know why some people have alignment problems and others do not, but I fall into the former category. Every alignment place I've taken my car to has told me that I need new camber bolts.
OP, can you link the site that you got those ones from? They look like they work perfectly!
Thanks.
Edit: Is this it? http://performance.importrp.com/spc_perfor...xr/g-62332.aspx
How many did you have to buy?
Edit: Also, hey everyone, what's up???
This post has been edited by CheesyLobster: Oct 9, 2011 - 3:53 PM
post Oct 9, 2011 - 7:37 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
^ When I put my s techs on, they said my camber was at the very most allowable negative camber that would, i guess you could say, pass the allignment.
So I didn't need camber bolts.
My Celica!
post Oct 10, 2011 - 8:09 PM
qatar11
From Lake Orion, MI
I have Ingalls Engineering Camber Kits... Ingalls Engineering A single bolt in each corner should allow for +/- 2 Degrees. I have two bolts in each corner...which should allow for approx +/- 4 Degrees. This is sorta the cheater method for adjusting the camber.
The "Proper" way to do it is to have camber plates at the suspension mounts... Like Thus:
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Oct 13, 2011 - 9:35 AM
QUOTE (CheesyLobster @ Oct 9, 2011 - 3:43 PM) *
Thanks.
same ones, i got 4.
post Oct 13, 2011 - 4:45 PM
k-weaver
Joined Jun 5, '07
From Santa Maria
I thought the front/rear was adjustable on our cars? When I lowered my car (KYB/Tein) I took it to a shop the same day and had all 4 adjusted and brought back into spec, no kit required.
post Oct 13, 2011 - 4:48 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
the lovwer you go the harder it is to get back within spec.
also watch out!!! alignment places will want to give your car a "safe" camber(0 to positive) instead of -1.5 to -0.5 Toyota specs.
post Oct 22, 2011 - 12:43 AM
chacha
Joined Dec 29, '05
From So-Cal
steph...should we ask them to keep it at -1.5 to -0.5? is this for both the front and rear?
post Oct 22, 2011 - 6:55 PM
post Oct 24, 2011 - 9:19 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
WHEEL ALIGNMENT SPECIFICATIONS TABLE
Application Preferred Range
1.8L
Camber (1)
Front ....................... -0.85 ....... -1.6 To-0.1
Rear ........................ -1.27 ..... -2.02 To 0.52
Caster (1) ................... 2.12 ....... 1.37 To 2.87
Steering Axis
Inclination (1) ............. 15.1 .....................
Toe-In (2)
Front ....................... 0 (0) ..... -0.08 To 0.08
(-2 To 2)
Rear .................... 0.14 (3.5) ..... 0.06 To 0.22
(1.5 To 5.5)
Toe-In (1)
Front ......................... 0 ......... -0.2 To 0.2
Rear ........................ 0.35 ....... 0.15 To 0.55
Toe-Out On Turns (1)
Inner ....................... 36.73 ....................
Outer ....................... 30.63 ....................
2.2L
Camber (1)
Front ....................... -0.77 ..... -1.52 To-0.02
Rear ........................ -1.17 ..... -1.92 To 0.42
Caster (1) ................... 2.08 ....... 1.33 To 2.83
Steering Axis
Inclination (1) ............. 14.97 ....................
Toe-In (2)
(-2 To 2)
Rear ...................... 0.14 (3.5) ... 0.06 To 0.22
(1.5 To 5.5)
Toe-In (1)
Inner ....................... 36.9 .....................
Outer ....................... 30.73 ....................
(1) - Measurement in degrees.
(2) - Measurement in inches (mm).
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 23rd, 2024 - 5:35 AM
