3 Pages V   1 2 3 >
> The motor in my celica now rests in peace. now w/ PICS, Bad rod bearing/nice hole in the block
post Apr 28, 2008 - 4:40 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
Well Saturday I was cruising 410 in San Antonio w/my friend, putting miles on the Integra I built Friday, at about 75. Wasn't speeding, racing, or putting any unnecessary stress on my car at the time. Well an incline came alone and my slushbox decides it needs to down shift. So I'm going up a hill at about 4.5K rpm. and i hear this quiet tapping start. then it slowly gets louder. I call up my friend real quick and tell him i blew my engine, so we pull over at the next exit. I top off my oil and we decide to go back to where we were staying that weekend. 10-15 miles away. So I drive back. Tapping slowly getting worse. So by the time I get into the Garage I'm stuck w/ this:
Video
This post has been edited by stephen_lee: May 21, 2008 - 8:04 PM
post Apr 28, 2008 - 4:58 PM
DEATH
Joined Dec 19, '07
From tx
Ouch bro - sorry to hear that. Swap it - you already have one small motor and a 1mz-fe swap ought to be a peice of cake biggrin.gif
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Apr 28, 2008 - 5:00 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
money now... isnt too abundant. it may be a bit before i can swap. so i may just do a quick rebuild so i can drive it again.
im really looking at the 3VZ-FE, though. almost bought one and all.. but that fell through
This post has been edited by stephen_lee: Apr 28, 2008 - 5:01 PM
post Apr 28, 2008 - 5:47 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
So does anyone think i could just replace all the rod bearings to get away with this for a few months?
post Apr 28, 2008 - 6:12 PM
politicsareevil
Joined May 1, '03
From Houston , Texas
I got a 7a-fe full engine for sale..... in houston....
- Matt
post Apr 28, 2008 - 7:11 PM
alltracman78
Joined Aug 9, '06
From Ma
I can't check the video [I'm at work], but I'm assuming you have rod knock.
You most definitly have a chance of the engine running fine if you just replace the bearings, but there's no guarantee. It all depends how badly you damaged the crank [if any] while you drove it like that.
Parts for this will be relatively cheap, 8 bearings [or 2 if you just do 1 rod], FPIG or silicone and exhaust gaskets/bolts/nuts.
Labor is a bit more, probably 2 - 3 hours.
post Apr 28, 2008 - 11:21 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE(alltracman78 @ Apr 29, 2008 - 12:11 AM) [snapback]669050[/snapback]
labor?
no no no. i don't do "labor" lol
i do it myself. i have a rebuild, a performance build under my belt, with a swap in progress.
im pretty sure its rod knock. definatly from the bottom end, engine runs on 4 cyl so i assume its not thrown or anything. just a little lost power. still idles and starts fine
post Apr 29, 2008 - 8:05 PM
6G96GT
Joined Jan 20, '08
From East Coast
I spun all the rod bearings on a Talon TSI i had and then turned the crank cause it was scored, replaced the rod/main bearings and then drove it for 250 miles before it spun another bearing...problem was in the oil pump, it got all chewed up apparently.
post May 2, 2008 - 3:26 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
wow so i bought the bearings. they are TINY compared to the B18 i built frown.gif
no wonder they had problems lol i will update in a few days as to how the motor stands
edit: i bought all 8 bearings. it sounded like i got just 2
This post has been edited by stephen_lee: May 2, 2008 - 3:28 PM
post May 2, 2008 - 3:27 PM
DEATH
Joined Dec 19, '07
From tx
Good luck man
This post has been edited by DEATH: May 2, 2008 - 3:28 PM
EXT: WRC/TRD/404
post May 2, 2008 - 3:36 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
b18 ones are large because it has an aluminum block.
cast iron blocks need less support.
post May 3, 2008 - 12:38 PM
addictions
Joined Sep 26, '07
From iowa
QUOTE(politicsareevil @ Apr 28, 2008 - 6:12 PM) [snapback]669027[/snapback]
- Matt
This post has been edited by addictions: May 3, 2008 - 12:39 PM
-Boss III
post May 3, 2008 - 7:03 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
ok, bearing in, crank was just a bit chewed, but i think it'll be ok.
engine runs again, no knock. hopefully nothing else will surface
post May 3, 2008 - 7:08 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
bearing in cyl 1 was non existent.. found .... its pieces in the bottom of the oil pan cyl 2 was pretty bad, but still there. others were ok.
This post has been edited by stephen_lee: May 3, 2008 - 9:25 PM
post May 3, 2008 - 9:14 PM
QUOTE(stephen_lee @ May 3, 2008 - 8:08 PM) [snapback]670418[/snapback]
pics, pics, so we can see, only if you can
post May 3, 2008 - 9:18 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
lets just say that it looked like aluminum foil shaved up.
post May 4, 2008 - 4:30 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
new isssues.
motor is dead.
threw a rod this time. nice hole in the block
post May 5, 2008 - 8:15 AM
DEATH
Joined Dec 19, '07
From tx
Damn man - sorry to hear that.
EXT: WRC/TRD/404
post May 5, 2008 - 8:26 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
GOOD IDEA haha. i should start collecting parts.
parts list:
3vz fe
e153
st205 mounts
st205 shift cables
shifter assy.
custom passenger mount
MegaSquirt
axles
some wire lol
post May 15, 2008 - 12:58 AM
deliriouzgtfour
Joined May 15, '03
From So Cal,CA
Thats how my car sounds when im driving down the road. I can feel it and hear it from underneath. CV boots still good with no tears. If anyone has an idea what it is pls feel free to PM me ..thanks
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: January 10th, 2025 - 5:13 AM
