DRL/Hi-Beams problem :(, Blown bulbs, not working! |
Apr 29, 2008 - 12:17 AM |
Enthusiast Joined Jul 27, '07 From Québec, Canada Currently Offline Reputation: 0 (50%) |
Hi, My wife's Celi has Daytime running lights and they are not working at all, neither the hi beams (related). Everything was working great since I made an engine bay pressure wash, but I didn't shoot water directly on relays and fuses, or bulb connections. I recently realize thet they were not working anymore, when I remove the bulbs (both) they were blown, tinted with black like fumes or something, and a large bubble were fromed in the side of them, seemed like they were having more than 12 volts maybe I replace them with new ones, and it's not working anymore. Anyone here have an idea, or wiring diagrams, it would be apreciated,
Thanx for the hints -------------------- |
Apr 29, 2008 - 2:41 AM |
Enthusiast Joined Nov 14, '06 From Northampton, UK Currently Offline Reputation: 5 (100%) |
QUOTE(GrimReaper @ Apr 29, 2008 - 6:17 AM) [snapback]669144[/snapback] Hi, My wife's Celi has Daytime running lights and they are not working at all, neither the hi beams (related). Everything was working great since I made an engine bay pressure wash, but I didn't shoot water directly on relays and fuses, or bulb connections. I recently realize thet they were not working anymore, when I remove the bulbs (both) they were blown, tinted with black like fumes or something, and a large bubble were fromed in the side of them, seemed like they were having more than 12 volts maybe I replace them with new ones, and it's not working anymore. Anyone here have an idea, or wiring diagrams, it would be apreciated, Thanx for the hints Does the high beam indicator illuminate on the dashboard? Check the following: * Headlight High LH, RH and DRL fuses. They are in the small fusebox on top of the radiator. * Daytime running lights relay. It is in the drivers' kick panel. Less likely: * Daytime running lights relays #3 & #4. They are in the small fusebox on top of the radiator. They would both have to be burnt out to describe the symptoms, though. * Check your dome light works. If not, replace the 10A dome fuse in the drivers' kick panel (it supplies power to the DRL integration relay (ECU)). * The DRL integration relay (ECU). I believe it is under the steering wheel somewhere. * Steering stalk controls (combination switch) http://www.celicatech.com/vfewdsou/1995/95...ic/hdlitcan.pdf ...try the service hints at the bottom of page 100 (page 3). -------------------- Davey
Items for sale |
Apr 29, 2008 - 7:29 AM |
Enthusiast Joined Aug 17, '03 From Bloomington, Indiana Currently Offline Reputation: 62 (98%) |
We have DRL's???? Well, I mean, is it an option? I know I don't have it....
Man I feel like a noob now -------------------- |
Apr 29, 2008 - 7:35 AM |
some countries required DRL, Canada for an example, Canadian Market Celica's have DRL, I don't think it was an option, it was more to satisfy local laws, like Cali smog for US celicas.
Apr 29, 2008 - 1:45 PM |
QUOTE(Culpable04 @ Apr 29, 2008 - 7:35 AM) [snapback]669190[/snapback] some countries required DRL, Canada for an example, Canadian Market Celica's have DRL, I don't think it was an option, it was more to satisfy local laws, like Cali smog for US celicas. Exactly, required by canadian laws since december 1989 (still required) Thanx for the informations BloodyStupidDavey, I'll have a look as soon as my wife comes back from work -------------------- |
May 9, 2008 - 5:49 AM |
* Daytime running lights relays #3 & #4. They are in the small fusebox on top of the radiator. They would both have to be burnt out to describe the symptoms, though. You were wright BloodyStupidDavey, the DRL relay #4 was burnt out, packed with rust, thanx a lot -------------------- |
Lo-Fi Version | Time is now: November 23rd, 2024 - 6:23 PM |
