> who has done a beams swap
post May 1, 2008 - 8:24 AM
I have searched in the forums to see who has done a beams swap. as there is not much info on this swap
Some people rate it 190 some even 210 hp. I am talking about the red top vvti engine.
Im starting to get info on this. So if anybody can point me to the right post/people. thanks...
I checked dr tweaks website and hes done one, but not much info.
The best is to get a clip, yes but these are hard to come by, so i need to know what is needed..
post May 1, 2008 - 9:32 AM
azian_advanced
Joined Apr 18, '05
From Calgary
Outsider
puretone
Kev_GT
post May 1, 2008 - 9:50 AM
azian_advanced
Joined Apr 18, '05
From Calgary
PM me your e-mail and i'll send you the diagrams
post May 1, 2008 - 11:19 AM
done thanks.
post May 1, 2008 - 9:08 PM
BTW
the ssIII, what is the transmission? same as ours?
post May 3, 2008 - 8:14 AM
Outsider
From Kelowna, BC
I have a 94 GT-S (5S-FE). I had to use the BEAMS motor, my original flywheel and clutch my motor mounts. My original tranny also fit fine. As yet I have no Cat because the BEAMS has it on the end of the header under the drivers seat. I put an adapter pipe in instead. The BEAMS tach is also needed as the engine uses the new style ignition and the signals are different. your old tach will not work with the BEAMS. Wiring is not that bad if you have some previous electrical experience. Just take your time.
This post has been edited by Outsider: May 3, 2008 - 8:16 AM
1994 GT-S (BEAMS) swap complete
post May 3, 2008 - 7:35 PM
QUOTE(Outsider @ May 3, 2008 - 9:14 AM) [snapback]670293[/snapback]
thanks man, im really going for this swap, the fact is i cant due to money issues.
so far i have recognized i need
engine
ECU
Cluster
Wiring
I can use my own tranny, my mounts.
What about the other little stuff, like ignitors, air intake, fuel pump.
I have researched sometimes the beams does not like a CAI due to the MAF having abnormal signals and running sluggish when the engine is cold.
I am a member of MR2.com since I have seen they are doing this more often. glad to know someone has already done it on a celi.
I am the NEXT FTW......
post May 18, 2008 - 10:09 PM
sugarfree
Joined Dec 21, '05
From dallas
The beams tach is required? i thought that was on the 5gens. I thought the 6gen cluster will still work with the correct wiring, well 96 and up.
post May 18, 2008 - 10:36 PM
99Celica
Joined Nov 1, '07
From Santa Barbara, CA
Can a celi be legally registered in Cali with a BEAMS engine?
post May 19, 2008 - 12:54 AM
Rusty
Joined Nov 5, '07
From New Zealand
I was thinking about down a beams swap, but more rewarding to work with my 3S-GE Gen3 smile.gif
because $2,300NZD for Beams swap? for just 20kW
post May 19, 2008 - 1:49 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
QUOTE (sugarfree @ May 19, 2008 - 3:09 AM) *
As far as I know you need either a BEAMS tach or a tach adapter box like this one: http://www.phoenixtuning.com/zenstore/inde...p;products_id=4
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post May 19, 2008 - 6:39 AM
QUOTE (Dr_Tweak @ May 19, 2008 - 2:49 AM) *
-Doc
ill let you do the wiring
post May 19, 2008 - 12:34 PM
sugarfree
Joined Dec 21, '05
From dallas
Oh yeah doc is right. At one point i was looking at the MSD one. Ill need to order that and have you send it to me with my harness when your done.
post May 19, 2008 - 12:46 PM
goferris
Joined Feb 14, '07
From Provo, UT USA
QUOTE (njccmd2002 @ May 3, 2008 - 6:35 PM) *
you would probably be better off finding one that still has the tranny attached. it should still just drop in. if you get one without a tranny it's possible that you could get an automatic ECU that wont work with the manual tranny. is the beams tranny a e153? i've head that it has an LSD
QUOTE (99Celica @ May 18, 2008 - 9:36 PM) *
no. the only swap that you Californians can legally do is if you have a 94-95 GT you can swap in an MR2 (smog legal) 3sgte. the reason being you can only swap a motor that is the same year or newer than your car and have it legal and in cali it has to be a smog legal (or whatever they call it) motor with california emissions regulations.
do people have swaps that aren't legal in cali? of course! they just know people who know people who "overlook" the illegal swap.
This post has been edited by goferris: May 19, 2008 - 12:46 PM
post May 19, 2008 - 1:28 PM
99Celica
Joined Nov 1, '07
QUOTE (goferris @ May 19, 2008 - 1:46 PM) *
post May 19, 2008 - 8:22 PM
or you can live in another state like mine, and visit california year round.
ayways, yes i know about the ecu, now bout the tranny, would i need to modify my axles? I know a lot of people favor the 3sgte, but i just have fallen in love with the beams...
post May 19, 2008 - 8:41 PM
sugarfree
Joined Dec 21, '05
From dallas
The beams tranny is a s54LSD. Same GT axels.
BTW, anyone know what the part numbers for manual engine mounts for a GT?
This post has been edited by sugarfree: May 19, 2008 - 8:42 PM
post May 20, 2008 - 3:28 PM
96ST206
Joined Jan 6, '08
From Oak Ridge TN
QUOTE (njccmd2002 @ May 19, 2008 - 9:22 PM) *
x2 on that! I'm from San Diego CA originally and now stationed in SC I love it no emission laws FTW!! I love the BEAMS engine a guy on ebay named keithtau (rpm garage) has a SSIII gauge cluster for sale white face, 9000rpm tach, but he wants like 250-300 shipped though.
If anyone needs info on the Toyota Curren feel free to PM me!
post May 24, 2008 - 3:35 AM
pasqual
Joined Nov 4, '06
From POLAND
I did this swap to my st202 half year ago .....
I can provide You all info ..what you need
QUOTE (njccmd2002 @ May 1, 2008 - 9:08 PM) *
BTW
S54-06d .... this gearbox is in beams (not all beams have LSD) ..... all S54 gear-box will fit beams ..
I think you have already wiring diagram if not PM me ....
QUOTE (njccmd2002 @ May 3, 2008 - 7:35 PM) *
engine
ECU
Cluster
Wiring
ECU ...there is project on mr2.com - BEAMS .... seams You can use aftermarket ecu for 1zz-fe smile.gif
more info about swap .
http://www.6gc.net/forums/index.php?showto...mp;#entry632592
BEAMS swaped .......
post May 24, 2008 - 3:39 AM
pasqual
Joined Nov 4, '06
From POLAND
Edited: I posted twice smile.gif by mistake ....
QUOTE (Dr_Tweak @ May 19, 2008 - 1:49 AM) *
-Doc
This post has been edited by pasqual: May 24, 2008 - 3:40 AM
Lo-Fi Version Time is now: February 18th, 2025 - 6:33 PM
