> Spark plug shooting out
post May 2, 2008 - 9:05 AM
Stu37363
Joined Jun 30, '05
From Chattanooga, TN
Could a bad/slipping timing belt cause a spark plug to shoot out?
post May 2, 2008 - 9:09 AM
tighten down your spark plugs next time!
(answer is no) (secondary answer is you didn't tighten your spark plugs)
post May 2, 2008 - 9:34 AM
Stu37363
Joined Jun 30, '05
QUOTE(playr158 @ May 2, 2008 - 10:09 AM) [snapback]670054[/snapback]
i tighten them to hand tight, i was told tighter could crack the housing or strip the threads, maybe hand tight and a quarter turn?
post May 2, 2008 - 10:08 AM
1/2" socket driver and nice and snug
post May 2, 2008 - 10:25 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
yeah go like a quarter turn after its snug.
hope your head isnt ruined that would suck.
my buddy shot a plug into his hood on his neon.
we managed to get a new one in there but lets just say thats the last plug that cylinder will ever see. biggrin.gif
post May 2, 2008 - 10:40 AM
Stu37363
Joined Jun 30, '05
i got it back in, its snug now, if it comes out again i guess i have a bigger problem
post May 3, 2008 - 8:39 AM
IIRC the BGB calls for 13ftlbs. on the spark plugs.
the next time you install fresh plugs, once you tighten them hand tight, turn it the next 1/2 or so turn nice and slowly, you should be able to feel the washer "seat" against the head, once it does, your good.
post May 7, 2008 - 8:11 AM
Stu37363
Joined Jun 30, '05
Ok, plug came out again and it looks like it stripped the threads on the block, what part do i need to replace to fix this?
post May 7, 2008 - 8:54 AM
need to pop off the head and heli-coil the spark plug shaft.
post May 7, 2008 - 9:33 AM
Stu37363
Joined Jun 30, '05
QUOTE(playr158 @ May 7, 2008 - 9:54 AM) [snapback]671439[/snapback]
yeah i picked up a kit today, i called the local dealership and talked to a mechanic and he said i didnt have to remove anything from the engine, but i couldnt get the tool in there as it is.
post May 7, 2008 - 9:37 AM
Stu37363
Joined Jun 30, '05
what tools should i need?
what parts need to be removed?
what if anything will need to be resealed?
if anyone knows i would appreciate it, trying to find the link to the bgb, but i forget where it is located.
post May 7, 2008 - 10:28 AM
pull the head
post May 7, 2008 - 10:57 AM
stevest202
Joined Oct 28, '07
From epworth uk
QUOTE(Stu37363 @ May 7, 2008 - 9:37 AM) [snapback]671459[/snapback]
the easiest way to helicoil spark plug threads is remove the head so have a new head gastket to hand to rebuild
post May 7, 2008 - 11:07 AM
Stu37363
Joined Jun 30, '05
ive been trying to research this since i have never done it. looks like im going to have to remove the cams and everything. can anyone point me in the right direction? the bgb link i think i need on celicatech is dead and i would love to do this myself.
so i know ill need a new head gasket, and probobly some sealant for the valve cover, my timing belt needs replaced so i guess this would be a good time to do it as well? i saw a walkthrough for that already. im surprised i couldnt find more information on the head; seeing as how the head gasket is replaced by a lot of the turbo setups.
This post has been edited by Stu37363: May 7, 2008 - 11:09 AM
Lo-Fi Version Time is now: November 23rd, 2024 - 9:59 AM
