> Project GT400 how it all began
post May 2, 2008 - 9:09 AM
mrgt4
Joined Mar 27, '08
From england
bought it as a standard import celica st205 GTFour, all the extras from factory included.
how the engine used to look...
then the changes began..
first off a blitz nur spec r exhaust system..
then the aussie 3" front pipes to join the blitz
then the process of gutting the under bonnet insulation and removal of stock intake for apexi power intake..
then the blitz DSBC was installed for a bit more fun..
a ceramic aussie 3" downpipe was installed to remove the cat / downpipe combo to make the system a 3" straight through from the turbo out..
turbos in good nick... twin wastegate design of the ct20b
all installed...
i then decided to spray the heatshield to make it nicer.
couple of coats and looks much better
toyota sprint series happend...
and then i realised how much boost creep i got in winter time, we tested the intake temps with the charge cooler installed and it wasnt a viable option to run 1.2 bar boost so this also had to go.....
poor car
for my nice big fmic from forge... cost the price of a small car! redface.gif lol
trial fitments happend
then we finally finished the pipework and the bits put back together, it is beleive to be the only st205 using a ic this size to retain all oem coolers and foglights in the original mounting locations. smile.gif
8 weeks later and alot of effort..
all back in and boost creep cured do to having such massive capacity in comparison to the cc setup, intakes down massively, and all good for me to drive the nurburg and donington park at flat out pace! biggrin.gif
things not seen as tein suspension and TRD low temp thermostat
1994 ST-205 JDM GTFour... fmic conversion finshed, project GT500 is underway
www.rising-sun-racing.com
tuning , performance, repairs and conversions... Blitz, TRD and many more suppliers :)
post May 2, 2008 - 10:12 AM
very nice!
looks like a great start and seeing some track work being done is always awesome!
post May 2, 2008 - 11:53 AM
DiP203
Joined Dec 9, '07
From West Haven, CT
looking good
post May 2, 2008 - 1:16 PM
zero07
Joined Apr 15, '07
From san antonio tx.
Really nice!
post May 2, 2008 - 1:56 PM
mrgt4
Joined Mar 27, '08
From england
cheers guys!
as for track time... not long to go till i go around donington again!!
off around next friday night with my mates, my gt4, another st205 , a 1jz-GTE supra, and a evo 5 i think. biggrin.gif
will make sure to get lots of pics!
post May 2, 2008 - 6:40 PM
Rusty
Joined Nov 5, '07
From New Zealand
how much psi & HP are you pushing?
are you going for a larger turbo next? & whats your next plans?
keep us updated
This post has been edited by Rusty: May 2, 2008 - 6:42 PM
post May 2, 2008 - 8:22 PM
dtlwrc
Joined Jun 26, '07
From Greece
Really nice work! Great looking car!
post May 3, 2008 - 12:36 PM
mrgt4
Joined Mar 27, '08
From england
QUOTE(Rusty @ May 2, 2008 - 6:40 PM) [snapback]670201[/snapback]
keep us updated
psi im running around 1.2 bar so what.... 17psi i think.
bhp wise, i ran a 304.7bhp, 301lb/ft @ 1.04bar way back last year for banzai magazine in a rolling road shootout, mods at the time were:
blitz nur spec r system
aussie front pipe
apexi intake
blitz dsbc running 1.04bar
still running standard cat / dp combo
spec now stands at
aussie front pipe
aussie downpipe (ridding of cat too)
apexi intake
forge FMIC with custom pipework and brackets
blitz dsbc running 1.2bar
so im not sure what bhp / torque it is now but id expect say what... 320+
as for next plans, yeah the turbo is the next step forward, we used larger outlets on the ic so that if / when i uprate the turbo we are all fine and not restricting air flow or anything. smile.gif
i want massive response over flat out bhp though, as i use it quite alot for the odd trackday and most is quick flat out acceleration, so i cant be having any lag problems so that leaves me to what turbo we should use. kindasad.gif
just been out today for a run... 3 st205's! both me mates for a thrash about, rather good fun to say the least! biggrin.gif
This post has been edited by mrgt4: May 3, 2008 - 12:38 PM
post May 4, 2008 - 10:29 AM
Awesome car!
At the crank right?
There is no way you hit 304hp at the wheels at only 15psi on a ct20b, especially with a 4wd car.
post May 6, 2008 - 2:06 AM
mrgt4
Joined Mar 27, '08
From england
Lo-Fi Version Time is now: November 23rd, 2024 - 3:57 AM
