> Rear Speaker Install, & Rear seats removal
post May 2, 2008 - 8:12 PM
Rusty
Joined Nov 5, '07
From New Zealand
I just Installed my New Rear Speakers and as I finished putting the speakers in. I thought I'll do a write up so....
Tools
and wire crimps (but not needed if your using a soldering iron)
New Speakers 6.5"
Time: about 2 hours
First thing you have to do is remove the rear seats. Easier to move if you take out the parcel tray, unclip the back rest, so it folds down. Undo the velcro push the carpet in the boot/trunk back as you need to undo the (x4) buttons (green circle top, and purple bottom) hold the flap under the seat up and undo (x4) bolts (Gold circles) on the bottom of the Back rest, push the back rest down into the seat so they clear the clips next to the bolts
(another view)
DO NOT REMOVE THE MOUNTING IN THE MIDDLE FOR THE BACK REST
(this holds and moves the Back rest up and down, its unnecessary to do so, and could put the back rest out of alignment )
Now with those out the way we can remove the seat, you might want to use a screwdriver to prey up the seat, as there are (x2) clips holding it down, push the seatbelts through the hole, then just lift the seat up over the mounts.
Now the easier part; remove the speaker cover and panel. Remove the (x5) bolts in the green circles
Remove the srews in the gold circles (the green ones remove the speaker mounting, you could now go out and buy some speakers with this, making sure that the speakers will fit )
Install & wire up your new Speakers (you might need smaller screw heads so hold the speaker, but these could come with the speaker)
(CHECK YOUR SPEAKERS GO)
Then start putting the panels back in.
The rear panel has to go in behind the boot panel, watch out for your seatbelts, then push the panel in so it 'snaps' into place Screw that bottom screw in last (in the above picture) so the panel doesn't wobble and make noises
Then put the seats back in*
(apply some pressure and it will 'snap' into place) make sure you bring your seltbelts back through the hole
*(Always remove cats from your comfy seats before install)
(another view)
then clip back your parcel tray back in
Enjoy your New Speakers installed by you
This post has been edited by Rusty: May 15, 2008 - 9:58 PM
post May 2, 2008 - 8:17 PM
nice, how much for the speakers,
post May 2, 2008 - 8:24 PM
Rusty
Joined Nov 5, '07
From New Zealand
their the 2008 model about NZ$70
post May 5, 2008 - 9:25 PM
Spart
Joined Apr 17, '08
From Iowa
Ha! I was looking for something like this a week ago, where were you man?
I'm doing much the same - except my 6.5" brackets are out. Some FG magic and they're going to be sealed 8" enclosures for a pair of these:
http://cdtaudio.com/sub_woofers_08.htm
post May 6, 2008 - 12:53 AM
creis
Joined Jan 10, '04
From Shoreline, WA
you stole my cat, give it back.... on second though keep it.
This post has been edited by creis: May 6, 2008 - 12:54 AM
post May 6, 2008 - 12:59 AM
CelicaST_CALI
Joined Feb 28, '07
plz god tell me u named him Garfield...
BANNED. for life, you moron.
post May 6, 2008 - 2:12 AM
BloodyStupidDave...
Joined Nov 14, '06
From Northampton, UK
QUOTE(creis @ May 6, 2008 - 6:53 AM) [snapback]671045[/snapback]
Your cat? I thought he was my cat!
post May 6, 2008 - 3:55 AM
Rusty
Joined Nov 5, '07
From New Zealand
lol nah it's a she
I could lift the tail up to prove it..... but thats going a bit to far tongue.gif
well why didn't you do a write up for me? lol
I will add some better detailed pics this weekend, but otherwise add to write up sticky?
post May 6, 2008 - 10:45 AM
Sinyk
Joined Oct 4, '06
From Kelowna, BC Canada
Nice writeup. I did mine the lazy way and just reached down the side panels with a socket wrench and removed it then pulled the side panel enough to get the speaker out (they flex very far). Quite easy and you don't have to remove your seats.
post May 6, 2008 - 11:13 AM
lubu
Joined Apr 2, '07
From Great Western Plateau
98% completion
aaRon
post May 6, 2008 - 11:44 AM
DEATH
Joined Dec 19, '07
From tx
QUOTE(Sinyk @ May 6, 2008 - 10:45 AM) [snapback]671112[/snapback]
x10 [done it that many times probably laugh.gif waaaay easier than removing the seats/plastics]
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post May 7, 2008 - 1:42 AM
Rusty
Joined Nov 5, '07
From New Zealand
yeah it is DS
well we have a front speaker one might as well have a rear one, but yes you are right. I just didn't want to brake anything
post May 7, 2008 - 4:36 AM
gate4sweden
Joined May 31, '07
Hi good job!
i just want to say tha you dident need to take out your back seats i menaged to do the work without taking them out!
post May 7, 2008 - 12:59 PM
DEATH
Joined Dec 19, '07
From tx
No - this is def a good write up and a good write up should always be the correct way of doing things - not the ghetto easy way like most of us take [we can figure out that one by ourselves].
Good job. Vote 1 for sticky.
This post has been edited by DEATH: May 7, 2008 - 12:59 PM
EXT: WRC/TRD/404
post May 15, 2008 - 9:59 PM
Rusty
Joined Nov 5, '07
From New Zealand
did a little fix up & added a 2 more pics
post May 15, 2008 - 11:51 PM
joehernandez
Joined Aug 5, '06
From San Luis AZ
nice write up!
the cat looks really tired though!!!!
post Jun 7, 2008 - 5:43 AM
good job. added to the stickys!
post Jun 7, 2008 - 5:49 AM
BloodyStupidDave...
Joined Nov 14, '06
QUOTE (joehernandez @ May 16, 2008 - 5:51 AM) *
Of course! It is a lot of work, supervising.
post Jun 8, 2008 - 2:17 AM
Rusty
Joined Nov 5, '07
From New Zealand
thanks presure2
post Jun 9, 2008 - 7:08 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Looks like your aftermarket speaker fit straight in there, I had to hack and slash my factory front speakers to make a mounting plate for mine to fit, this isn't necessary in the back? Never got round to that part unfortunately, Well maybe fortunately that I didn't have to rip up the back to retrieve speakers with bruised ribs lol
Mike W
269awhp / 273ft-lbs
Lo-Fi Version Time is now: November 22nd, 2024 - 12:00 PM
