WTF |
WTF |
Sep 3, 2003 - 4:34 PM |
Enthusiast Joined Apr 14, '03 Currently Offline Reputation: 0 (0%) |
Suppose your buying the Piston kit by Ross. Do you customize the specs or take it stock cause its designed for the 3sgte.
P.S. if you know then reply please if you not sure dont. |
Sep 3, 2003 - 11:24 PM |
The title is the way it is cause know one ever answers. (97sccelica thank you for your reply) Ive been on the boards forever and all my basic questions are still floating around. (mostly technical I guess)
Reason for the question is under the parts database is says the pistons will fit in any chasis code. Hmmm wierd |
Sep 3, 2003 - 11:36 PM |
Enthusiast Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
i dont see how 3sgte specific pistons could be used in any other motor (besides maybe a 3sge) without being modified, as said before the displacement and bore size are completely different between the 3s, 5s, 7a, or any of the older celica motors. not saying they couldnt be modified, but if you are going to spend a ton of money on ross pistons just to modify them, id say go find something thats made specifically for the motor you are using... unless the goal is changing compression ratios, bore sizing, and displacement. id recommend JE pistons for that kind of stuff. if thats the case, then you are on your own, cuz no one one this site would beable to walk you through what your are doing, cuz we have no idea what you are involving in your project... so we all have the same reaction to the topic as you... WTF. it was probably a typo on either coomer or whoever posted the part on the databases part.
-------------------- Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Sep 3, 2003 - 11:43 PM |
Enthusiast Joined Jul 8, '03 From tucson az Currently Offline Reputation: 0 (0%) |
If I'm not mistaken the bore size on the 3s and 5s are the same 86; I am under the impression the that the stroke is what is different and that is when you take into account the head. So the pistons should work for you but the connecting rods and bearings are where you may run into problems. Hope this helps.
Johnny |
Sep 3, 2003 - 11:56 PM |
I want to get the web cam hard weld but the one that boosts mid-high reccomends high compression pistons along with a apex safc. so thats what the plan was and our data base said they would fit but I guess it would be harder than I thought
Sep 4, 2003 - 1:31 AM |
Enthusiast Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) |
well, 3sgte pistons would not be the way to go for high compression. they are low compression pistons. it would be best to go custom. it may be more $$$ but it will be less of a hassle than trying to modify low compression pistons in to high compression pistons(is that possible?) -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Sep 4, 2003 - 2:44 AM |
Enthusiast Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) |
Pauter, Crower and eagle all make pistons for the 5sfe and can do high comp or low. From what I understand the 3s ones are to small for the 5sfe. Think about it if they fit you would see tons of people using them. The rods however do fit but have to be shortned frist.
-Bryan- -------------------- Member of Team 5sfTe
Lo-Fi Version | Time is now: November 27th, 2024 - 12:45 PM |
