Eliminate Flexpipe? |
May 4, 2008 - 9:31 PM |
Enthusiast Joined Dec 9, '07 From PhiLLy Currently Offline Reputation: 0 (0%) |
My flex pipe between the header and catalystic converter has an exhaust leak... I was wondering, is it possible to eliminate the flex pipe and get a pipe welded where the flex pipe is suppose to be without hurting the car?
This post has been edited by PHLCELICA: May 4, 2008 - 9:32 PM -------------------- Celica *The Baby Supra*
May 4, 2008 - 9:39 PM |
Enthusiast Joined Nov 15, '07 From Attleboro Mass Currently Offline Reputation: 1 (100%) |
No, you need the flex pipe to be there so the exhaust won't crack when the engine flexes.
-------------------- QUOTE Surprise buttsecks always works fine for me. 1994 Toyota Celica ST 1977 Harley Sportser XLH 1992 Ford F-350 (plow truck) |
May 5, 2008 - 5:38 AM |
QUOTE(PHLCELICA @ May 4, 2008 - 10:31 PM) [snapback]670643[/snapback] My flex pipe between the header and catalystic converter has an exhaust leak... I was wondering, is it possible to eliminate the flex pipe and get a pipe welded where the flex pipe is suppose to be without hurting the car? why not have a new flex installed. you can get the flex section for ~30$ or less. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
May 6, 2008 - 2:06 PM |
Enthusiast Joined Sep 29, '05 From Rochester, Massachusetts Currently Offline Reputation: 2 (100%) |
I'm looking for that flex section, where can I purchase one?
-------------------- The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed? |
May 6, 2008 - 2:17 PM |
Enthusiast Joined May 1, '03 From Michigan Currently Offline Reputation: 0 (0%) |
JC Whitney
http://www.jcwhitney.com/autoparts/Product...p?Ntt=flex+pipe Summit Racing http://store.summitracing.com/egnsearch.as...inresults=false -------------------- Scott
West Michigan |
May 6, 2008 - 3:28 PM |
I wouldn't remove it, adds needed flex to hard pipes.
May 7, 2008 - 1:02 AM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
QUOTE No, you need the flex pipe just get a new one, you need one in This post has been edited by Rusty: May 7, 2008 - 1:09 AM -------------------- |
May 7, 2008 - 7:39 PM |
Well I ordered the flex off of summit but cut the old one out and got a pipe welded on as a temp. fix...
BTW... may sound pretty stupid, but is a flex pipe pretty much universal? -------------------- Celica *The Baby Supra*
May 7, 2008 - 8:08 PM |
Enthusiast Joined Jan 11, '07 From Rochester, NY Currently Offline Reputation: 0 (0%) |
don't weld solid just tried it and just broke this morning sounds horrible
-------------------- [img=http://img56.imageshack.us/my.php?image=signature2fs0.jpg]
May 15, 2008 - 5:31 PM |
Enthusiast Joined Nov 5, '07 From westminster md Currently Offline Reputation: 0 (0%) |
Anybody know which one (part no. or specs) Will replace stock flex pipe?
I'm almost ready for inspection! |
Lo-Fi Version | Time is now: November 27th, 2024 - 4:17 AM |
