> Starting problems, Not exactly sure what it is, little help please?
post May 5, 2008 - 12:18 PM
bmrabb
Joined Dec 24, '07
From Cumberland, RI
So my car has had starting problems recently. I turn the key and it clicks once...that's it. The engine doesn't crank or anything. After I try a few more times, the car starts up perfectly fine.
I'm not really sure what the problem is. Is it the starter? Or could it be something else.
Just wondering if anyone had any ideas or the same problem and how you fixed it.
Thanks alot,
Brandon
post May 5, 2008 - 3:19 PM
Hanyo
Joined Aug 16, '03
From Bay area
its your starter
post May 5, 2008 - 10:27 PM
CelicaST_CALI
Joined Feb 28, '07
o jesus...lol ur in my shoes about 3 years ago,this started happening to me about 3 years ago,ill save u some $,the mechanic told me it was the starter contacts inside the starter and he wanted 300$ to do it....Now i drove it for 3 years,well my dad did, with this prob,now this weekend it crapped out completely :'( :'( so all ya got to dois replace the starter,easyer said than done,hope that helps....
BANNED. for life, you moron.
post May 5, 2008 - 11:29 PM
bmrabb
Joined Dec 24, '07
From Cumberland, RI
Alright. Thanks guys.
Now is this a "not too hard" diy project?? Or should I just bring it somewhere and have it done?
post May 5, 2008 - 11:46 PM
CelicaST_CALI
Joined Feb 28, '07
well obviously u need to buy a new starter,then u disconnect neg bat cable,then u get under ur car and take the 2 wires off,one is a 12mm bolt and the other pops off,then there are to bolts that are a pita to get off,u take out the air box and pull out the starter and then put the new one in..
post May 6, 2008 - 7:28 AM
its easy as pie, tops 1 hour job... make sure you have 6 inch and 3 inch socket extensions too...
post May 6, 2008 - 11:15 PM
CelicaST_CALI
Joined Feb 28, '07
u make me laugh...have u ever pulled a 7a starter?^^
post May 6, 2008 - 11:37 PM
Havok1997GT
Joined Nov 23, '07
From Houston TX
QUOTE(CelicaST_CALI @ May 6, 2008 - 11:15 PM) [snapback]671365[/snapback]
X2
It isnt as easy as you think. Its not impossible, but not easy, even if you have done it before. Now the 5s start, that one is easy, its right up front, but the 7as is behind the intake, making it a lot harder.
Lo-Fi Version Time is now: November 26th, 2024 - 10:03 PM
