Enginel lagging at low rpm |
May 13, 2008 - 9:16 PM |
Enthusiast Joined Apr 24, '04 From S. Cali Currently Offline Reputation: 0 (0%) |
I've been having problems with this for awhile...first it was bad plug wires, so i changed those along with a new cap and rotor, everything was fine untill about a week ago. Now the car is bogging down at low rpms, usually when starting from a complete stop. I have to rev the engine a bit to get it moving normally. It only happens from idle to about 25-3000 rpm. From 3000 up the car is nice and smooth. Any suggestions??? Next on my to do list is new plugs.
thanks |
May 13, 2008 - 9:29 PM |
Enthusiast Joined Oct 18, '06 From cincinnati Currently Offline Reputation: 10 (100%) |
mine does similarly, heard plugs should fix it. it like hesitates around 2k and jumps after a couple seconds of what seems like bogging.. then again w/as many miles as i have on this damn thing it could be a whole list of problems..
-------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
309,000 miles n' .... |
May 14, 2008 - 8:50 AM |
is it misfiring or does it just not have power?
how many miles are on it? and how many since you replaced the plugs? is it getting bad gas mileage? -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
May 14, 2008 - 10:56 AM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
From what you are describing it has nothing to do with spark or fuel. Whens the last time you've done your clutch? If you have to rev it up to get going its your clutch slipping. Its not all done yet. You should check that when you get a chance, because when your clutch goes you won't be moving any where any time soon.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
May 14, 2008 - 12:43 PM |
Check for vac leaks.
May 14, 2008 - 12:51 PM |
Enthusiast Joined Mar 28, '08 From Washignton Currently Offline Reputation: 1 (100%) |
Please clarify bogging?
If the engine itself bogs (stumbles, doesn't want to rev) then check plugs and for vac leaks If the engine revs fine, but the car doesn't move or barely moves until 3k rpms, chances are your clutch may be going - though clutch usually doesn't slip until you try to give it gas (ie if babied it will be slower going but still holds) -------------------- '92 ST185, '88 ST165, '05 Galant LS, '08 Legacy
May 14, 2008 - 2:27 PM |
it could be valve timing if it takes higher rpms to get power from a 7A, and 'bogging' at lower RPMs. but for sure check for vacuum hoses off/damaged and check and replace plugs, wires, and cap/rotor. is your CEL light on?
May 14, 2008 - 4:08 PM |
This is totally lame, but I concur with the spark plugs idea. Also, when's the last time you put in a clean air filter? Injector cleaner? Little things like that that add up to an even slower 7AFE than ever before!
May 14, 2008 - 5:25 PM |
Enthusiast Joined Sep 26, '07 From iowa Currently Offline Reputation: 1 (100%) |
This is totally lame, but I concur with the spark plugs idea. Also, when's the last time you put in a clean air filter? Injector cleaner? Little things like that that add up to an even slower 7AFE than ever before! LOL -------------------- -Boss III
May 14, 2008 - 6:16 PM |
Thanks for the replies...i fixed it. I got new plugs...solved everything. From what my dad told me he had never changed them!!! Those plugs had close to 200k miles on em!!!
May 14, 2008 - 7:18 PM |
valve leaks x2
-------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
May 14, 2008 - 9:46 PM |
whoaa.. 200K miles on one set of plus.. go toyota
Lo-Fi Version | Time is now: November 23rd, 2024 - 12:10 AM |
