GTS rims with spacers, Anybody ?? |
May 14, 2008 - 9:02 PM |
Enthusiast Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
Hey, anybody with gts wheels running with spacers and have pics ?? Wanna see how well they look like with spacers and with a drop if possible Thanks.
So post up some PICS !! -------------------- "To Protect And To Serve The Wealthy" -POLICE
May 14, 2008 - 9:06 PM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
i got 5mm spacers front and back. hold on for the pics.....pics are with bad alignment.......still
This post has been edited by 808celica: May 14, 2008 - 9:12 PM -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
May 14, 2008 - 9:09 PM |
May 15, 2008 - 12:56 AM |
Enthusiast Joined Apr 24, '04 From S. Cali Currently Offline Reputation: 0 (0%) |
Sweet ride!!! Hey did you need to use longer wheel studs or did you just use the stock ones??
May 15, 2008 - 2:11 AM |
Enthusiast Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) |
oh be naughty and run some 20mm like sprynt did!
-------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
(2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
May 15, 2008 - 2:43 AM |
Enthusiast Joined Jun 30, '06 From West Windsor NJ, USA Currently Offline Reputation: 14 (94%) |
-------------------- --------------------------------私は銀行に漂う,TRD Inspired |
May 15, 2008 - 3:05 AM |
lolz soon i promise...
no i have stock studs. 5mm isnt that fat of a spacer. if i do get 20mm or 15mm spacers.....is there a set that just bolts on to the old studs and the spacer has its own studs for the wheel?? cuz i dont feel like taking apart my hub and spindel to get to the stockies......... -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
May 15, 2008 - 10:28 AM |
Nice pics anybody have some with 10+ spacers ??
May 15, 2008 - 7:42 PM |
Enthusiast Joined Jan 17, '04 From Boston, MA Currently Offline Reputation: 1 (100%) |
> Today, 04:05 AM
> 808celica > '95 GT Hatchback > if i do get 20mm or 15mm spacers..... > is there a set that just bolts on to the old studs and the spacer has its own studs for the wheel?? There are set of 20mm. Just hope the wheel has an indentation for the studs which will protrude a bit. 25mm H&R DRM are the best bet, bolt on to wheel, bolt wheel to spacer. Quick Google searrch.... http://www.optionsauto.com/products.asp?de...n=&sort_by= Regards; |
May 15, 2008 - 9:19 PM |
Quick question bout the 10mm...is it really necessary to use the extended studs with them?? Cuz i was looking at em and they aren't really that thick...i want to kick the rear wheels out a bit and i don't think 5's will be enough...
May 16, 2008 - 3:18 AM |
yes the 5mm's arent good enough. i would go 25mm but im not into that fat wheel look. 15mm - 20mm is good enough for me. heck 12mm would be great.
10mm should be fine just try not to hit turns too hard or your studs might give out -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
May 19, 2008 - 4:38 PM |
^^^ Hey 808celica what brand are your spacers ??
May 19, 2008 - 5:50 PM |
Enthusiast Joined Oct 12, '05 From Texas Currently Offline Reputation: 59 (100%) |
If you get spacers, don't cheap out on them. These are your wheels we're talking about - the connection between you and the road. Correct me if i'm wrong, but i think H&R makes the best spacers out. I think they run $250+
-------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Current: 850rwhp C6 Corvette Grandsport, Gen1 6.2L Ford Raptor |
May 19, 2008 - 9:20 PM |
^^^ Hey 808celica what brand are your spacers ?? i dunno i got it from one of my gen.7 celica guys in CCO i doubt 5mm will do anything severe. i know if you get cheap 20mm ones then yeah they'll bug out. are the H&R ones a plug and play set of 4???? cuz my friend with the new IS-F(white) bought i think the h&r's and he has to get longer studs. he didnt get the plug and play This post has been edited by 808celica: May 19, 2008 - 9:21 PM -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
May 19, 2008 - 11:04 PM |
from the link posted a few posts up (Options Auto Salon), they come in pairs only.. which is great cuz i'm looking to get spacers that are a bit wider in the rear than the front.
i'm thinking about getting 15mm front and 20mm rear (H&R) sorta like Kadett's and Tech9ine's setup. This post has been edited by azian_advanced: May 19, 2008 - 11:12 PM -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
May 19, 2008 - 11:11 PM |
are the H&R ones a plug and play set of 4???? cuz my friend with the new IS-F(white) bought i think the h&r's and he has to get longer studs. he didnt get the plug and play They SHOULD come with longer studs, and be plug and play. Check before you purchase though. -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
May 19, 2008 - 11:14 PM |
from what i can tell, H&R has the extended lugs already built-in inside the spacer (plug & play)... where as the Ichiba spacers has the lugs separate from the spacers which will require more work like removing the brake rotor and swapping the stock lugs for the extended ones.. is that right?
This post has been edited by azian_advanced: May 19, 2008 - 11:16 PM -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
May 19, 2008 - 11:18 PM |
btw, there has been a few threads about spacers for 7th gen GT-S rims.
http://www.6gc.net/forums/index.php?showto...&hl=spacers http://www.6gc.net/forums/index.php?showto...&hl=spacers -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
May 20, 2008 - 10:47 AM |
Yeah I've seen those threads but they didn't have any pictures with spacers.
This post has been edited by Remy: May 20, 2008 - 10:47 AM -------------------- "To Protect And To Serve The Wealthy" -POLICE
May 20, 2008 - 11:15 AM |
Enthusiast Joined Apr 15, '08 From Powder Springs GA Currently Offline Reputation: 0 (0%) |
sorry im new and dont know how to post up pics yet but i have gts rims so check my profile if you want
Lo-Fi Version | Time is now: November 24th, 2024 - 7:29 AM |
