engine noise through speakers, any advice? |
May 15, 2008 - 11:26 AM |
Enthusiast Joined Oct 5, '05 From Milwaukee Currently Offline Reputation: 1 (100%) |
I just recently upgraded my system to Kappa components and 2 ways in the rear. It is all powered through an 08 model infinity 4 channel amp. I get engine whine through my speakers with the volume low. when the music is up I dont reall hear. any way to get rid of it??
May 15, 2008 - 11:29 AM |
Enthusiast Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) |
ground loop reducer/isolator.
But that dont always work, (not very well atleast) Find a new ground. If nothing else, run a line off your batt. That'll delete all that unwanted noise. -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
May 15, 2008 - 11:40 AM |
Enthusiast Joined Nov 14, '06 From Northampton, UK Currently Offline Reputation: 5 (100%) |
ground loop Yup, it is a ground loop problem. They can be rather tricky to resolve but search these forums for "ground loop" and you'll find a couple of threads with suggested approaches to resolving the problem. -------------------- Davey
Items for sale |
May 15, 2008 - 6:03 PM |
Enthusiast Joined Feb 28, '07 Currently Offline Reputation: 1 (100%) |
it could be wat type of spark plugs you are using,does it change when u accelerate?
-------------------- BANNED. for life, you moron.
May 15, 2008 - 6:14 PM |
QUOTE Ground loop is a condition where an unintended connection to ground is made through an interfering electrical conductor. Generally ground loop connection exists when an electrical system is connected through more than one way to the electrical ground. When two or more devices are connected to a common ground through different paths, a ground loop occurs. Currents flow through these multiple paths and develop voltages which can cause damage, noise or 50Hz/60Hz hum in audio or video equipment. To prevent ground loops, all signal grounds need to go to one common point and when two grounding points cannot be avoided, one side must isolate the signal and grounds from the other. This excerpted from http://www.epanorama.net/documents/groundloop/ -------------------- |
May 15, 2008 - 8:52 PM |
hmmmm...so basically I have a bad groung spot...rite? I will have to do sum more research
May 15, 2008 - 10:15 PM |
run you power wire and rca wires on opposite sides of the car.
also find a better ground. -------------------- |
Lo-Fi Version | Time is now: November 25th, 2024 - 4:26 PM |
