Is this worth it? |
Is this worth it? |
May 19, 2008 - 5:44 AM |
Enthusiast Joined Dec 4, '07 From Northeast Pennsylvania Currently Offline Reputation: 3 (100%) |
-------------------- QUOTE ‹Superaison› i'm a computer inclined guy.. ‹Superaison› or girl. idk what gender I am anymore. ‹SeverX13› *facepalm* QUOTE suprakid: o sh!t suprakid: i wanna get an obama chia pet SeverX13: hahahahaha |
May 19, 2008 - 10:08 AM |
Enthusiast Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) |
for $1?
DEFF!! -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
May 19, 2008 - 11:17 AM |
May 19, 2008 - 11:33 AM |
that my friend, you will have to ask him. If they work
Yes most every part on that list would be used in one of our setups. But; there was one or two things i think just don't apply to us. You could resell, or IDK... Just remember to do your research before starting into a boost project; that's only like half the stuff you need. Good Luck! -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
May 19, 2008 - 11:44 AM |
Enthusiast Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
sever, honestly, piece it together yourself. it will take longer, and it might cost u a bit more $$$ but in the end, ull know u have a quality build going on, and not something that was purchased off ebay, and are unaware of certain parts quality, or correctness.
Like presure2 says: "cheap, reliable, fast....pick 2" -------------------- Kawi Love |
May 19, 2008 - 1:41 PM |
well my budget is 2000. and id like to ahve it b4 DWG. ive been researching for a while now. but idk if i can do it for 2g's
May 19, 2008 - 2:07 PM |
well my budget is 2000. and id like to ahve it b4 DWG. ive been researching for a while now. but idk if i can do it for 2g's im gonna be honest... i dont think u can. ud be going the cheap, fast route...and i think 2k is TOOOO cheap. -------------------- Kawi Love |
May 26, 2008 - 10:34 AM |
you will regret it if you rush it. take the time, get more money raise your budget and get everything you need to turbo and and prepare the engine to hold more power
-------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
May 26, 2008 - 5:04 PM |
Enthusiast Joined May 8, '08 From Marietta, Ga Currently Offline Reputation: 0 (0%) |
Honestly, depending on where you piece together your kit from you can have a reliable turbo setup for around 2k. The build im looking at doing only costs 1800. and i have had many friends who have done similar low cost builds with fantastic results.
Given, those builds were not meant for 250+whp but usually ran about 8-10 psi and they have had no problems This post has been edited by SilvertopST: May 26, 2008 - 5:06 PM |
May 26, 2008 - 8:04 PM |
Enthusiast Joined Dec 24, '06 From jonesville Currently Offline Reputation: 4 (100%) |
thats abt. how much im planning on spending on mine...and im building the motor and boosting the 5sfe.
sorry im only planning on spending 2k for the turbo kit...not everything...but it still shouldnt b more than 3k for everything.i think thats a pretty good deal This post has been edited by Kerr1: May 26, 2008 - 9:06 PM |
May 27, 2008 - 12:32 AM |
thats abt. how much im planning on spending on mine...and im building the motor and boosting the 5sfe. sorry im only planning on spending 2k for the turbo kit...not everything...but it still shouldnt b more than 3k for everything.i think thats a pretty good deal 2k-3k for a reliable custom kit is not far out of the question. if you are tearing the motor apart and building it up to withstand higher boost levels than 8-10 psi then it will probably cost more than 2k, but if you are looking to just run about 8-10psi then, in most cases, the internals can hold that, and hold it reliably, as long as the compression on the motor is good. and the tuning is done and done right. This post has been edited by SilvertopST: May 27, 2008 - 12:33 AM |
May 27, 2008 - 10:16 AM |
well i have some stuff set up with shannon and jim, Im probably gettin a Ct20b kit .
May 27, 2008 - 1:02 PM |
3sgte rods = 50 bucks (thanx bccentaur)
getting the crank turned to fit= 300 bucks custom pistons w/ rings 9-1 compression=550 toga HP rod bearings=40 toga Hp main bearings = 60 arp head studs = 150 thats right at 1200 bucks and w/ those mods alone...no headwrk we can run more than 8-10 psi....prolly closer to 15psi...im still doing research but this is what i have done to my motor so far. but i should def. come out cheaper than 3k...after buying all the turbo parts.. Sever i would listen to them and save just a lil more money and do it right the 1st time and have a hellacious 5sfte. my opinon only tho. |
May 27, 2008 - 1:20 PM |
yes i am he said that it will end up being 2500-3000. its worth it tho, they know what they are talkin about
May 27, 2008 - 2:46 PM |
Thread:
Is this worth it? Quote: its worth it [/thread] -------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
Lo-Fi Version | Time is now: November 30th, 2024 - 7:07 AM |
