Enthusiast ![]() ![]() Joined Aug 6, '05 From cerritos, california Currently Offline Reputation: 10 (100%) ![]() |
need new rear hub and bearing.
any recommended sites online? thanks! -------------------- things happen for a reason.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) ![]() |
hub from a trashed 6gc and bearing you can get from a local auto parts store
![]() -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) ![]() |
try ToyotaWorld.com or 1stToyotaParts.com.
make sure you get one that corresponds to whether you have abs or not. This post has been edited by azian_advanced: May 19, 2008 - 9:55 PM -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) ![]() |
from Toyota the rear hub and bearing come together, you cannot get either separately and they are around $250-260 each from Toyota World.
If you were to get a hub from a junkyard and an aftermarket bearing it would probably be cheaper, I'm sure you can have someone press them together even though according to Toyota you either can't or it isn't recommended. -------------------- |
Lo-Fi Version | Time is now: February 22nd, 2025 - 10:28 PM |
