Enthusiast Joined May 22, '08 From ireland Currently Offline Reputation: 0 (0%) ![]() |
Hi,
I recently got a set of projectors for my st202 and after reading the info articles now know that the wiring needs tinkering with so i can get al 4 headlights working. In the info article, it says its a H1 bulb.... now i didnt get any adaptors or anything with the lights when they arrived and i got them from germany. Am i able to bodge the wires and spade connectors or is there a "proper" way to go about it? Any info would be a great help as i really am in the dark on this one. Thanks a million |
![]() Enthusiast ![]() ![]() ![]() Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) ![]() |
Youll need to get the H1 bulb holders for the lows, then its a matter of hooking the wires accordingly. The highs should be PnP.
-------------------- ![]() 98% completion --- aaRon |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) ![]() |
highs are the same bulbs as your old ones so no changes there
for the lows, its pretty simple. go to an auto parts store and buy an H4 harness, will have 3 connections arranged in a U shape and 3 pig tailes coming out the other end. the harness plugs right onto the h1 bulbs, and i just tinned the ends of the pigtails and inserted them into the car's harness. better details: i just got h4 connectors, pulled the one wire out of it so it was just the 2 that i need so it looks all clean, then the other end of the pig tails i just stripped them and tinned? them (made stiff w/ solder) then just inserted into the existing 9006 harness - this way no cutting and going back to stock is still possible, plus it looks clean =) just get diff diameters of heat shrink and make it all weather proof then, im working on that now actually took 3rd wire out ![]() simple connection no cutting ![]() -------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
![]() ![]() ![]() ![]() (2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
Perfect, thanks a million!
Lo-Fi Version | Time is now: February 20th, 2025 - 3:44 PM |
