> FS: JDM blinker & headlight stalks, SOLD
post May 23, 2008 - 4:03 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
This came with some fogs I got, but I'm not going to use it, so it only seems fair to offer it up to you guys! Make offer.
Here's some pix, practical and alluring! Note that the blinker stalk and the headlights/foglight stalk are reversed from the USDM stalks. I'm just too OCD to be able to adapt to this Left Hand Side of the Bed™ way of life.
^Full frontal.
^Left stalk, aka The Wiper & Turn Signal
^The right stalk, aka low beam, high beam and fog light controls. Note the fog light is controlled with a separate rotating switch similarly to the way the intermittent wiper speed is controlled.
^Original JDM wiring harness action. Wires and plugs in very good condition with no evidence of corrosion.
^Back side of the unit just for good measure. Sorry it's a little blurry.
This post has been edited by GriffGirl: Jul 29, 2008 - 12:14 PM
post May 23, 2008 - 4:38 PM
BloodyStupidDave...
Joined Nov 14, '06
From Northampton, UK
QUOTE (GriffGirl @ May 23, 2008 - 10:03 PM) *
This came with some fogs I got, but I'm not going to use it, so it only seems fair to offer it up to you guys! I'm looking for best offer but would be even happier to trade them with someone who has a stock push-button fog switch.
Wasn't someone on the forums looking to change their stock UK/US setup for a JDM setup just last week? Also, can you post the part numbers for the left and for the right stalk (even better if you can post the numbers for the US versions also)?
post May 23, 2008 - 5:09 PM
GriffGirl
Joined Feb 7, '07
I'm all for that, but I haven't got the slightest clue as to how to locate the PN for the USDM switch. The JDM stalks I have have lots of numbers on it, I believe the turn signal is a different PN than the light stalk, as is the center part they connect to.
post May 24, 2008 - 12:29 PM
celicadude04
Joined Dec 28, '04
Try these links
OEM Stalk part number
OEM Fog Light Switch
post May 27, 2008 - 1:35 PM
GriffGirl
Joined Feb 7, '07
^ Yuppers!
Bump! Still for sale!
post May 28, 2008 - 2:52 PM
BloodyStupidDave...
Joined Nov 14, '06
QUOTE (GriffGirl @ May 23, 2008 - 11:09 PM) *
They should have 10 digit number probably starting 84310, 84140, 84112 or 84650. However the UK ones have a six digit part number instead:
Left (Lights and turn - inc fog): 17A089
Right (Wipers/washers - inc. 4 position intermittent): 17A164 LH
post May 28, 2008 - 5:36 PM
ouch, but I hope it helps
http://cgi.ebay.com/ebaymotors/JDM-Toyota-...sspagenameZWDVW
QUOTE (njccmd2002 @ May 28, 2008 - 6:34 PM) *
and another one
http://cgi.ebay.com/ebaymotors/TOYOTA-FOG-...sspagenameZWDVW
post May 30, 2008 - 2:40 PM
GriffGirl
Joined Feb 7, '07
I saw those, thanks for lookin' out. I thought Toyota made round ones... I'm holding out for a round one. I may go to a junk yard and get a non-Toyota one, so it's round. I want to put it in that little circle on the left driver's heat vent.
Bump-a-Roni, the San Francisco treat.
post May 30, 2008 - 2:51 PM
BloodyStupidDave...
Joined Nov 14, '06
QUOTE (GriffGirl @ May 30, 2008 - 8:40 PM) *
The part numbers are:
84165-20040
84165-20060
The first part number is for the basic switch, which is the easiest to work with if you are going to mod. The second part number is for the smart switch - it has a few extra wires and some logic to ensure that the fogs only work with the correct combinations of other lights (ie you have to have your lights on but not your full beams). They look identical when installed. They are pretty hard to find in the US I understand - I'll keep a lookout at my local scrap yards for you.
UKDM / EDM spec foglights howto
This post has been edited by BloodyStupidDavey: May 30, 2008 - 2:52 PM
post Jun 27, 2008 - 4:57 PM
GriffGirl
Joined Feb 7, '07
Bump. I still have this if anyone's interested.
post Jul 4, 2008 - 7:49 AM
pipes
Joined Apr 23, '08
From boston MA
hey how muched shipped to 02136 i also am still parting out my gt anything you may need? il give it to you if i still have it let me know
post Jul 4, 2008 - 12:24 PM
FunkySR
Joined Apr 22, '07
From Buckinghamshire, UK
are you sure the turn stalk is not on the right side??
post Jul 4, 2008 - 12:26 PM
pipes
Joined Apr 23, '08
From boston MA
QUOTE (FunkySR @ Jul 4, 2008 - 12:24 PM) *
they are on the right side just like in europe and japan
post Jul 7, 2008 - 12:24 PM
GriffGirl
Joined Feb 7, '07
Sale pending. . .
post Jul 29, 2008 - 12:14 PM
GriffGirl
Joined Feb 7, '07
SOLD
Lo-Fi Version Time is now: November 30th, 2024 - 12:42 AM
