> Anyone know what this would be called?, And if you do, can you tell me where to get it?
post May 25, 2008 - 9:15 PM
CAMAricer
Joined Jul 25, '07
From San Francisco
I need a valve that only opens when the throttle is fully engaged (hard acceleration) but stays closed then idling/cruising.
This post has been edited by CAMAricer: May 25, 2008 - 9:25 PM
2002 SC430 (WC) - 19" SSR Comp-H, Daizen swaybars, Sparco Demons, JDM Soarer conversion, carbon fiber spoiler, Injen intake, front strut bar, drilled/slotted Brembo rotors
1997 Celica ST (DD) - 17" ADR, ViS Zyclone CF hood, ViS CF hatch, K&N intake, Invader body kit
post May 25, 2008 - 11:26 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
seems interesting
why do you need this valve?
post May 25, 2008 - 11:41 PM
urbandork
Joined Jul 16, '04
From Los Angeles
i have a few ideas... but what is this for?
post May 26, 2008 - 4:11 AM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
PM'd
post May 26, 2008 - 8:57 PM
CAMAricer
Joined Jul 25, '07
From San Francisco
Here's what I want to do:
BTW, this isn't a picture of my celica engine bay but it's shows you what I'm trying to achieve. Basically, it's a "two-stage" air intake system, where one air filter is always open and the second one only opens when you need it. The valve would be used control the air flow, limiting the volume but increasing velocity when engine demand is lower but increasing volume when demand is high.
post May 26, 2008 - 9:04 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
thats a good idea, but i thinks you wont see gains that your expecting
unless you take this idea further, into the intake manifold
but toyota has already done this. i believe its called TVIS
post May 26, 2008 - 9:22 PM
CAMAricer
Joined Jul 25, '07
From San Francisco
Yup, that's what Derrick told me too (about the TVIS).
So I see that it was used on the 4AGE and the 3SGE...wondering if it would work on a 7AFE... And what exactly is this TVIS?
On a separate (but related note), it seems that for better low end torque, a longer and narrower intake path is better than a fat short one (due to higher velocity). So...
Would something like this out perform a standard intake system?
QUOTE (stephen_lee @ May 26, 2008 - 9:04 PM) *
post May 26, 2008 - 9:29 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
that idea will still flow at the same speed unless some are closed at lower RPMs
but since its just an intake, i think most of that speed will be stopped by the throttle plate.
post May 26, 2008 - 11:02 PM
mariosdarkworld
Joined Aug 13, '07
From Arizona
Butterfly valve
post May 26, 2008 - 11:15 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (mariosdarkworld @ May 27, 2008 - 5:02 AM) *
Butterfly valve
that was my instinct to call it, but then i second guessed myself.
when i do that, it never turns out right. idk why i even try
post May 26, 2008 - 11:28 PM
CAMAricer
Joined Jul 25, '07
From San Francisco
Great! Now that it has a name, I can go about trying to secure it. Thanks!
QUOTE (mariosdarkworld @ May 27, 2008 - 12:02 AM) *
Butterfly valve
post May 27, 2008 - 1:15 AM
dans_st
Joined May 24, '03
From Andrews TX
so what you would basically like to do is split up the runner in a way to basically have one side closed for velocity then open the other "butter-fly" to allow more volume, right?
very rough but is this somewhat what you mean?
__________________
__________________<-plenum opening
[][] [][] [][] [][] <-dual runners
O[]-O[]-O[]-O[]---~ <-butterfly's to open/close secondary runners controlled by vacuum
if so -they do have this for the 7afe.
I have the head and intake I will try and post pictures tomorrow.
This post has been edited by dans_st: May 27, 2008 - 1:27 AM
If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
post May 27, 2008 - 3:34 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
GO ITB's laugh.gif like coomer's yeli celi
post May 27, 2008 - 8:28 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
all those pipes will = more weight, resistance and turbulence than one larger intake with a single filter.
just not practical imo. least restriction is what you want always on an intake. longer or shorter doesn't matter, as soon as the air is in the manifold all your piping is nun and void. you just want fresh air.
post May 27, 2008 - 9:54 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
GO ITB's :lol: like coomer's yeli celi
Can't. He would need to obtain a 20V head or get an adapter made up to mate the ITB's to the 7A head, then he would need engine management, tuning, etc.
All of that for ITB's? Might as well buy a 20V and drop it in.
..... and they are AWESOME!
**** Photobucket
post May 27, 2008 - 12:57 PM
dans_st
Joined May 24, '03
From Andrews TX
do you mean something like this, and also runner length does affect power and rpm range.
This post has been edited by dans_st: May 27, 2008 - 12:58 PM
post May 27, 2008 - 1:00 PM
monkey
Joined Nov 21, '07
From I-59 -N- 610 Houston, Tx
i know of valves for nitros that wont open unless ur foot is completely down on the petal....
post May 27, 2008 - 5:41 PM
urbandork
Joined Jul 16, '04
From Los Angeles
97 and up preludes had this exact same set up on their air intake boxes. the valve worked similar to an external waste gate on the turbo.
on another note the idea i had before was with a switch and solenoid which would be activated when the throttle cable attachment to the TB was pulled to the max... using an edge off the pulley to hit the switch which would activate the solenoid.
This post has been edited by urbandork: May 27, 2008 - 5:43 PM
post May 27, 2008 - 9:57 PM
dans_st
Joined May 24, '03
From Andrews TX
on the intake manifold that I had posted pictures of I believe that the second set of runners are closed under engine vacuum and when there is no vacuum the second set of runners are allowed to fully open.
so basically when you are at idle(engine vacuum) the second set is closed and as you press the throttle the the second sets opens as it gets closer to "0" vacuum(WOT)
This is not quite open ONLY at wide open throttle but could possibly be ran to some sort of vacuum switch to control it.
And also this is a 7AFE manifold and head incase someone did not know.
This post has been edited by dans_st: May 27, 2008 - 9:58 PM
post May 28, 2008 - 5:10 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
Lo-Fi Version Time is now: December 1st, 2024 - 7:39 PM
