2 Pages V  < 1 2
> Anyone know what this would be called?, And if you do, can you tell me where to get it?
post May 29, 2008 - 4:36 AM
dans_st
Joined May 24, '03
From Andrews TX
sorry I should have been more specific I believe that this is a JDM 7afe head.
If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
post May 29, 2008 - 3:03 PM
creis
Joined Jan 10, '04
From Shoreline, WA
I cant see you getting gains from this "butteryfly setup" on the intake pipe, there is just not enough resistance with a decent pipe and filter to worry about, also the stock 7a does not have a high enough redline to justify it either, but as far as real ITB setup its do-able and would give some gains but again for the amount of work does not seem worth it.
my opinion.
on a side note (kinda related but not)
I've see something like this for exhausts, setup a butterfly Y kinda think right after the manifold to 2 pipes 1 with stock cat,resinator and muffler and one thats straight pipe with hollowed out stock muffler, flip a swich and the stock exhaust closed as the straight pipe opens, gives you a emissions passing stock sounding car with a well hidden secrate. dont know how well it would work on a celica 7a or 5s but something else to think about. (I saw it on an episode of Trucks a while ago.
This post has been edited by creis: May 29, 2008 - 3:10 PM
post May 30, 2008 - 8:49 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (creis @ May 29, 2008 - 3:03 PM) *
i've seen someone on the board that has this.
i kinda want it. lol i get in the mood for a quiet car a lot, and sometimes a loud car i want too kindasad.gif
post May 30, 2008 - 8:58 PM
CAMAricer
Joined Jul 25, '07
From San Francisco
From where did that manifold come from?
QUOTE (dans_st @ May 27, 2008 - 9:57 PM) *
on the intake manifold that I had posted pictures of I believe that the second set of runners are closed under engine vacuum and when there is no vacuum the second set of runners are allowed to fully open.
so basically when you are at idle(engine vacuum) the second set is closed and as you press the throttle the the second sets opens as it gets closer to "0" vacuum(WOT)
This is not quite open ONLY at wide open throttle but could possibly be ran to some sort of vacuum switch to control it.
And also this is a 7AFE manifold and head incase someone did not know.
2002 SC430 (WC) - 19" SSR Comp-H, Daizen swaybars, Sparco Demons, JDM Soarer conversion, carbon fiber spoiler, Injen intake, front strut bar, drilled/slotted Brembo rotors
1997 Celica ST (DD) - 17" ADR, ViS Zyclone CF hood, ViS CF hatch, K&N intake, Invader body kit
post May 31, 2008 - 1:06 PM
dans_st
Joined May 24, '03
From Andrews TX
QUOTE (CAMAricer @ May 30, 2008 - 8:58 PM) *
It is for a 7AFE I believe it is a JDM 7AFE intake manifold and head, I don't remember exactly what kind of car it came off or if it was even a 6th gen celica, I have had it for a few years already and I can't remember anymore.
only odd thing about this head is that it does not have the hole for the distributor, I have not done research on them in a while but I could not find a 7AFE with an oem distributor-less ignition system.
I plan on probably losing the whole butterfly setup and just opening up and siamesing the intake and if I can, weld up and siamesing the intake as well so that way I can have more runner volume so that I can try and raise the rpm range up since the 7AFE's i smore torque oriented.
post May 31, 2008 - 1:24 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
i've seen the distroless 7a on ebay but thats it
2 Pages V  < 1 2
Lo-Fi Version Time is now: December 1st, 2024 - 7:47 PM
