help big time, fuel pump |
May 27, 2008 - 6:17 PM |
Enthusiast Joined Nov 23, '07 From massachussets Currently Offline Reputation: 0 (0%) |
my alternator + belt spark plugs and wires distributer cap and rotory but there was still a problem with my car ideling so i went on here for help and i was told to get my fuel injectors cleaned out. when i got it finished my car worked like brand new but i just recently went away on vacation with out me car for three days . i returned and started up my car it started up perfectly and was idling perfectly but heres the problem when eevr i put the pedal all thge way to the flooor it doesnt give me maxx horse power it only gives me a little the car still moves but not as fast as when i first fo the car its been happening for a very long time its lacking power big time. when i press on my gas pedal lightly its a very smooth ride its only when i speed i have loss of horse power. i thought it would be fuel related because i got my fuel injectors cleaned out last friday and after i got it done it didn't have that problem anymore. Is it the fuel pump? fuel Filter? idle air control motor? or does the timing just need to be adjusted? this problem has been driving me up a wall some one help me out please
May 27, 2008 - 6:22 PM |
Timing belt off a tooth?
May 27, 2008 - 8:34 PM |
but that would cause loss of power at ALL throttle positions
if, as he says, power is normal at less than 50% throttle then at >50% power isnt normal then it shouldnt be the tbelt. id replace all of your filters. pcv, air, and fuel. See if that helps any -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
May 28, 2008 - 12:11 PM |
Enthusiast Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) |
x2 @ stephen lee, I'd change out all filters first.
-------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
May 28, 2008 - 3:53 PM |
Enthusiast Joined May 28, '08 From mn Currently Offline Reputation: 0 (0%) |
my alternator + belt spark plugs and wires distributer cap and rotory but there was still a problem with my car ideling so i went on here for help and i was told to get my fuel injectors cleaned out. when i got it finished my car worked like brand new but i just recently went away on vacation with out me car for three days . i returned and started up my car it started up perfectly and was idling perfectly but heres the problem when eevr i put the pedal all thge way to the flooor it doesnt give me maxx horse power it only gives me a little the car still moves but not as fast as when i first fo the car its been happening for a very long time its lacking power big time. when i press on my gas pedal lightly its a very smooth ride its only when i speed i have loss of horse power. i thought it would be fuel related because i got my fuel injectors cleaned out last friday and after i got it done it didn't have that problem anymore. Is it the fuel pump? fuel Filter? idle air control motor? or does the timing just need to be adjusted? this problem has been driving me up a wall some one help me out please my alternator + belt spark plugs and wires distributer cap and rotory but there was still a problem with my car ideling so i went on here for help and i was told to get my fuel injectors cleaned out. when i got it finished my car worked like brand new but i just recently went away on vacation with out me car for three days . i returned and started up my car it started up perfectly and was idling perfectly but heres the problem when eevr i put the pedal all thge way to the flooor it doesnt give me maxx horse power it only gives me a little the car still moves but not as fast as when i first fo the car its been happening for a very long time its lacking power big time. when i press on my gas pedal lightly its a very smooth ride its only when i speed i have loss of horse power. i thought it would be fuel related because i got my fuel injectors cleaned out last friday and after i got it done it didn't have that problem anymore. Is it the fuel pump? fuel Filter? idle air control motor? or does the timing just need to be adjusted? this problem has been driving me up a wall some one help me out please Same thing happened to me. Turned out to be a weak coil which was hard to diagnose. |
May 28, 2008 - 4:12 PM |
Enthusiast Joined Nov 21, '07 From I-59 -N- 610 Houston, Tx Currently Offline Reputation: 0 (0%) |
are u sure the distributor was put back in the right place... did u mark it before u took it out.. could cause offiring...
my alternator + belt spark plugs and wires distributer cap and rotory but there was still a problem with my car ideling so i went on here for help and i was told to get my fuel injectors cleaned out. when i got it finished my car worked like brand new but i just recently went away on vacation with out me car for three days . i returned and started up my car it started up perfectly and was idling perfectly but heres the problem when eevr i put the pedal all thge way to the flooor it doesnt give me maxx horse power it only gives me a little the car still moves but not as fast as when i first fo the car its been happening for a very long time its lacking power big time. when i press on my gas pedal lightly its a very smooth ride its only when i speed i have loss of horse power. i thought it would be fuel related because i got my fuel injectors cleaned out last friday and after i got it done it didn't have that problem anymore. Is it the fuel pump? fuel Filter? idle air control motor? or does the timing just need to be adjusted? this problem has been driving me up a wall some one help me out please and yall thought i was bad at english... even i can barely understand what he said! |
May 28, 2008 - 4:22 PM |
other than needing an occasional Comma (,) or apostrophe (') i think the spelling and grammar were fine... @ Monkey
May 28, 2008 - 4:24 PM |
but if u read the first sentance what did u do twith the alternator and all that other fancy car stuff....! replace it? take it out? burn... i i i say burrrrnnn it..............
mmmmmmmmmmm fire.............. |
May 28, 2008 - 4:34 PM |
haha comon guys some ppl could be offended by you picking at their spelling/grammar.
but with that said, are we getting misfiring or just lack of power? -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
May 28, 2008 - 4:36 PM |
any time u deal with any timing parts, its a good idea to mark them..... it could even be a spark plug wire on the wrong spark plug... do u have pictures....
Lo-Fi Version | Time is now: November 23rd, 2024 - 5:34 PM |
