> help car wont star after swap, 2nd gen 3sgte in 94 celica st
post May 28, 2008 - 10:21 AM
02bluerolla
Joined Aug 31, '05
From Houston TX
well i just finish putting the engine in and wiring up the car. Well i start to crank it but it wont start. i check for spark and theres spark. i check for fuel and turns theres no power to the fuel pump or injector. well i disconected the fuel line that goes on my filter and gasoline started to spray everywhere. i cant think of anything except the fuses, well i checked and none are burned . now iam running out of ideas and dont know what to do . i called doctor tweak and he was helping me go through to daignose my car but i cant use a multimeter lol so i told i called him when i find someone that can. so now am looking for help here at the forums , any help would be apreciated.
post May 28, 2008 - 10:55 AM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
well the reason for mine not starting was that wires on the wiring harness that was suppost to kick the clutch pedal sensor to kick the starter was switch around i dont know if the third or the 2nd gen is different,but ask tweak..
post May 28, 2008 - 11:21 AM
02bluerolla
Joined Aug 31, '05
From Houston TX
QUOTE (RUNNIN-LOW @ May 28, 2008 - 10:55 AM) *
i dont think is that dude since my car cranks
post May 28, 2008 - 12:04 PM
creis
Joined Jan 10, '04
From Shoreline, WA
sounds like mine, check the EFI relay and if you have a test light pop out the fuse box and check underneet to make sure eveything is getting power, and from there can check the relays are tripping. double check the injector wires, ensure there connected correctly (in case you removed the wires) mine when I put the wires back it seemed obvious but I did it backwards, injector 1 and 3 get the brown wire, 2 and 4 get the gray wire.
It would not be the clutch pedal sensor if it cracks,
post May 28, 2008 - 1:23 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
ok one more little thing have u check the timing to see if it was correct that could cause your car not to start too if it cranks..since you said you was getting fuel pressure (cause i think u did say that gas did spray everywhere when u took the fuel line off) and spark..but do what u gotta do first.
post May 28, 2008 - 1:59 PM
urbandork
Joined Jul 16, '04
From Los Angeles
QUOTE (creis @ May 28, 2008 - 10:04 AM) *
on my third gen swap i had to rewire in the efi relay too
post May 28, 2008 - 2:14 PM
Ground your igniter by bolting it down.
Make sure your resistor pack is connected and grounded.
Make sure your COR and fuel pump relays are connected (next to the ecu).
Check the ecu for any stored codes (even if your dash light isn't on).
post May 28, 2008 - 3:23 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
question.. what exactly DOES the circuit opening relay do?
post May 28, 2008 - 10:21 PM
02bluerolla
Joined Aug 31, '05
From Houston TX
QUOTE (lagos @ May 28, 2008 - 2:14 PM) *
okay well tomorrow i will check for codes , but where exactly is the fuel pump relay located cause i been looking and cant finded.
post May 29, 2008 - 3:40 PM
02bluerolla
Joined Aug 31, '05
From Houston TX
anyone?
post May 29, 2008 - 4:12 PM
creis
Joined Jan 10, '04
From Shoreline, WA
I can check when i get home for you (around 4pm though.) my problem ended up bing a combination of things first my timing was +5 degress, 2nd my EFI relay and a few surrounding fuses were a little lose on the wire side, my map sensor was using the nipple on the intake mainfold sending switch rather then right on the manifold, and my manual was wrong about the firing order, book said (left to right) 4,3,2,1 when its 1,2,3,4,
post May 29, 2008 - 5:03 PM
scothaniel
Joined May 1, '03
From Michigan
You may not have a fuel pump relay depending on how the car was wired up. On the ST and GT models, the Circuit Opening Relay powers the fuel pump. For the 3SGTE's, they added the fuel pump relay and a resistor after the COR (triggered by the ECU's fpr wire) which runs the pump in reduced voltage for normal driving and full voltage when under load.
On my swap, I didn't install the fuel pump relay and am running at full voltage all the time.
You can test the fuel pump by jumping FP and B+ in the diagnostics box.
COR is basically just a latching fuel pump relay.
This post has been edited by scothaniel: May 29, 2008 - 5:06 PM
Scott
West Michigan
Lo-Fi Version Time is now: November 29th, 2024 - 12:36 PM
