oil leaking. . update.. More problems.., Need some more help! :/ |
May 28, 2008 - 5:16 PM |
Enthusiast Joined Apr 6, '08 From Overland Park Currently Offline Reputation: 9 (100%) |
Ok well I'm guessing car has been leaking it ever since I got it over a year ago, its not a fast leak, I have to add a quart maybe 2 every month tho, and I would prefer that it was just fixed. . Idk if it would be leaking from the oil pan? Basically I have oil all over the underside of the engine, nothing on the front but the bottom side is coated. I will try to get some pics on here to show but that will prolly happen tomorrow when I'm putting my header on. . Any help or ideas on where or why its leaking would be great! My dad thought it just burned oil but if it was just burning oil then I wouldn't have all this oil on my engine, it doesn't leak on the garage floor maybe a few drops in over a month, I think it burns on the engine but yeah. . Thanks in advance
UPDATE: OK well it's been a while but, I replaced the valve cover gasket and the problem pretty much let up for a while. Didn't really see much oil on the driveway for quite some time things were looking good, But within the last 2 weeks it's been leaking pretty bad.. I just did a degreaser and what not but it's still so coated on there I'm trying to wipe everything down and trying to pinpoint it but not having much luck.. It's on the passenger side backside of the engine, it looks as tho to be low as if out of the oil pan but there isn't a ton of oil all over it.. yes some but if that gasket is leaking its not the main leak and not that bad of one, any other ideas???? anything you would recommend I look at or try to replace? I'm a do-it-myselfer so if you can be descriptive.. This post has been edited by bseaman_5: Aug 15, 2008 - 1:51 PM -------------------- |
May 28, 2008 - 5:21 PM |
Enthusiast Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
Had that problem too, oil all over stuff in the bottem of car but not enough to drip on the ground. The mechanic guy told me that it was because of a bad seal around the valve cover. Havent fixed it yet (waiting till im on leave) but im guessing its never been replaced, so its about time that I would haev to do that.
May 28, 2008 - 5:24 PM |
Ok. That would make sense! Thanks! I'll prolly give that a shot. I should be able to do that myself right?
valve cover gasket isnt sht to do. took me like 10 min
May 28, 2008 - 5:25 PM |
Sweet! Did you have the same problem?
May 28, 2008 - 5:34 PM |
well my car was leaking worse than yours, and then burning oil too.
it was so bad at one point that oil was coating my passenger side. -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
May 28, 2008 - 5:37 PM |
Yeah, I would say that's pretty bad! Say any ideas how to get all that oil cleaned up off my engine once I replace that?
May 28, 2008 - 5:43 PM |
Enthusiast Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
My car used to leak oil like crazy too when I first bought it, all I did was give it a tune-up then the problem disappeared my oil doesn't drop anymore. Also check your rear main seal they like to leak on these 5sfe motors over time. Theirs also some stuff you can pour into your oil and it'll make it change color or something like that I've never used it but I'm sure you can find that stuff at your local auto store it'll help you pinpoint the leak.
-------------------- "To Protect And To Serve The Wealthy" -POLICE
May 28, 2008 - 5:53 PM |
Rear main seal?? Sorry I'm dumb. .
May 28, 2008 - 5:58 PM |
rear main seal is the seal where your crank comes out of the block. its like a gasket, but allows rotation.
i'd say just take your car to a good car wash that has some of that "degreaser" and give your whole engine bay/under body a good spray -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
May 28, 2008 - 6:02 PM |
Sounds like a plan! I think I'm going to just go ahead and replace the valve cover gasket tomorrow I'll clean up the engine and see what happens after that
May 28, 2008 - 6:51 PM |
if not, could be your oil pan gasket too
which is.. "fun" to replace -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
May 28, 2008 - 7:42 PM |
now looking at the valve cover.. How do I go about getting it off??? So confused, call me an idiot its ok!
May 28, 2008 - 8:05 PM |
not sure on the 5s, but the 7a there are like 4 bolts on the valve cover
it'll take some persuasion to take off. but do NOT pry it off -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
May 28, 2008 - 8:07 PM |
well I looked for some bolts but I didn't see anything!
May 28, 2008 - 8:10 PM |
well I looked for some bolts but I didn't see anything! wow I def feel like an idiot! I'm pretty sure I figured it all out! -------------------- |
Aug 15, 2008 - 1:52 PM |
bump need new help, updated above..
Sep 4, 2008 - 4:24 AM |
Enthusiast Joined Apr 5, '06 From PITTSBURGH, PA Currently Offline Reputation: 0 (0%) |
bump, I feel that this is the problem that I'm having as well..... Update requested...
This post has been edited by Celi94bk: Sep 4, 2008 - 4:25 AM |
Oct 20, 2008 - 8:54 PM |
Enthusiast Joined Jun 3, '06 Currently Offline Reputation: 0 (0%) |
if you are asking about the bolts to get the valve cover off on a 5s-fe take out the rubber things that go to the spark plugs and there are bolts under them (i just did this a few days ago and had to look on here to find out where they are) be careful when you torque them down, too tight might cause issues.
Oct 20, 2008 - 10:14 PM |
get a UV kit at a NAPA auto parts store or at an auto store.
you put it in your oil and then use the uv light it comes with to see where the water comes out of. -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Lo-Fi Version | Time is now: December 1st, 2024 - 7:42 AM |
